Why can't you break the limit of x*sin(1/x) into two separate limits?
  • Thread starter krackers
In summary, when solving the limit { lim }_{ x\rightarrow 0 }\quad xsin(\frac { 1 }{ x } ), it is not valid to break it into { lim }_{ x\rightarrow 0 }\quad x\quad *\quad { lim }_{ x\rightarrow 0 }\quad sin(\frac { 1 }{ x } ) due to the fact that lim_{x\rightarrow 0}sin(1/x) does not exist. Instead, it is more accurate to use the squeeze theorem and show that the limit is bounded between -x and x, which both approach 0 as x approaches 0. This shows that the limit is 0.
krackers
72
I was wondering why when solving this limit, you are not allowed to do this:
[itex]{ lim }_{ x\rightarrow 0 }\quad xsin(\frac { 1 }{ x } )[/itex]
Break this limit into:
[itex] { lim }_{ x\rightarrow 0 }\quad x\quad *\quad { lim }_{ x\rightarrow 0 }\quad sin(\frac { 1 }{ x } ) [/itex]
Then, since, sin(1/x) is bounded between -1 and 1, and lim x-> 0 (x) is 0, the answer should be 0.
That's not rigorous enough, because [itex]lim_{x\rightarrow 0}sin\frac{1}{x}[/itex] doesn't exist. But what you can do is say that [itex]-x\leq xsin\frac{1}{x}\leq x[/itex] for all [itex]x\neq 0[/itex], and [itex]lim_{x\rightarrow 0}(-x)=lim_{x\rightarrow 0}(x)=0[/itex], so by the squeeze theorem [itex]lim_{x\rightarrow 0}xsin\frac{1}{x}=0[/itex]
"That's not rigorous enough, because lim x→0 sin1 x doesn't exist."
I have to agree with this person. That limit doesn't really make sense. It only loops through a ratio. Because it loops through a ratio along with another variable, it makes the limit of the function an oscillating one, you have to check the derivatives instead.
1*sin(1/x) - x(-1/x^2)(sin1/x)(cos1/x)
take apart the trigonometric functions... because they only loop through -1 and 1
1 + (1/x)
... and you get an idea of where the limit is going as approaches 0
This is showing you that the derivative is unstable. It just does not level off.
lim(x->0) for sin(1/x) will just continue to oscillate as sin(1/x) flucuates through ratios. This should support the person's above statement that the limit doesn't really exist, and that values will always be between 1 and -1.
I am not so sure however myself. I haven't done some of this kind of work in a year. Can anyone add more input? I can't remember the exact procedure for checking this one's limit.
The actual limit cannot be zero as a result of the oscillating functions. Just think, if 1/x allowed x to get smaller and smaller, 1/x as a function would continue to grow. It ends up as sin (+t) where t continues to increase without bounds. The sine function still can only go to one. Even when being subjected to proportion adjustments from it's neighbor variable x. Hence, X * sin(+t) cannot have a zero limit, it really looks more like (k)sin(+t) if you think about it. It will never leave the 1*k and -1*k range.
It is hard to explain, but if you check your calculator it might make a little more sense. Just use .01 sized values for x in the function sin(1/x) Notice that these values when multiplied with the same value of nearby x will still be in flux. Using my own calculator, I see now when checking with .01 sized values that 0 in fact cannot be the limit, check for yourself!
Punch this is in and say I showed you how...
xsin(1/x) and then use DELTATBL=.001
check the tables and you will see exactly what I mean...
It is from here that you should be able to say that the limit might actually be zero...
There's no mathematical sound meaning to [itex]\,\lim f(x)g(x)=\lim f(x)\cdot \lim g(x)\,[/itex] if any of these limits doesn't exist, yet
you too can tell what you said, namely: if
[tex]\lim_{x\to\ x_0}f(x)=0\,\,\text{and}\,\,\,g(x)\,\,\,\text{ is bounded in some neighbourhood of}\,\,x_0[/tex]
then [tex]\lim_{x\to x_0}f(x)g(x)=0[/tex]
The [itex]\,\epsilon - \delta[/itex] is very simple.
DonAntonio
It isn't too hard if you think about it. Consider the sequence {x_n} = {1/pi, 1/2pi, 1/3pi, ...}.
Then sin(1/x_n) = 0 and thus goes to 0 as n goes to infinity.
Similarly, consider {y_n} = {2/pi, 2/5pi, 2/9pi, ...}. Then sin(1/y_n) = 1 and thus goes to 0 as n goes to infinity.
Since you have two subsequences approaching 0 such that the original function approaches two different vales, the limit cannot exist.
The wanted limit is when [itex]x\to 0[/itex] , not to infinity.
DonAntonio
DonAntonio
Yes, x_n and y_n are going to 0. The index n is going to infinity. I merely created sequences x_n and y_n that approach 0 such that sin(1/x_n) and sin(1/y_n) approach different values.
Substitute x = 1/t. Then the limit we want becomes [itex]\displaystyle \lim_{t\to\infty}\frac{\sin(t)}{t}[/itex]. And, sine is a bounded function: [itex]-1 \leq \sin(x) \leq 1[/itex]. This puts the limit in the form of the direct application of the squeeze theorem.
Can you take it from there?
It doesn't matter what the sine approaches: it is bounded everywhere and, in particular, it is bounded in any neighbourhoodo f zero. Since the other functions approaches zero the whole thing approaches zero, too.
DonAnronio
DonAnronio
I know what the OP's original question is. The point of my post was to help illustrate why sin(1/x) does not have a limit as x goes to 0.
Ok. Perhaps next time it'd a good idea to quote from the OP what you're addressing. In your first post you talked
about "the original function", which goes to zero, and apparently you were reffering ONLY to part
of it, namely to [itex]\,\sin 1/x\,[/itex] . This may be confusing.
DonAntonio.
DonAntonio.
I thought it was easily inferred...
What is the limit of x*sin(1/x) as x approaches 0?
The limit of x*sin(1/x) as x approaches 0 is 0. This can be shown by taking the limit as x approaches 0 of both x and sin(1/x), which both approach 0. Therefore, the product of x and sin(1/x) also approaches 0.
Why does the graph of x*sin(1/x) have a vertical asymptote at x=0?
The graph of x*sin(1/x) has a vertical asymptote at x=0 because the function is undefined at this point. As x approaches 0, sin(1/x) oscillates infinitely between -1 and 1, causing the function to have a vertical asymptote at x=0.
What is the behavior of x*sin(1/x) as x approaches 0 from the left and from the right?
As x approaches 0 from the left, x*sin(1/x) approaches 0 from below. This can be seen by substituting a negative value for x, which will make both x and sin(1/x) negative, resulting in a positive product. As x approaches 0 from the right, x*sin(1/x) approaches 0 from above. This can be seen by substituting a positive value for x, which will make both x and sin(1/x) positive, resulting in a positive product.
Is x*sin(1/x) continuous at x=0?
No, x*sin(1/x) is not continuous at x=0. The function is undefined at this point, as sin(1/x) oscillates infinitely between -1 and 1. This causes a discontinuity at x=0, making the function not continuous.
Can L'Hopital's rule be used to find the limit of x*sin(1/x) as x approaches 0?
Yes, L'Hopital's rule can be used to find the limit of x*sin(1/x) as x approaches 0. By taking the derivative of both the numerator and denominator, the limit can be rewritten as the limit of sin(1/x) as x approaches 0, which is equal to 0. Therefore, L'Hopital's rule can be used to find the limit of x*sin(1/x) as x approaches 0.
  • Calculus
  • Calculus
