Limit of a 3d function
  • Thread starter PenKnight
f(x,y) is a hybrid function
1. ( ( xy+x )^3 ) / ( x^2 + xy ) when (x,y) not equal to (0,0)
2. 0......................................when (x,y) = (0,0)
Is this function continuous at the origin?
.......lim.......df |(x,y) = df(0,0)
(x,y)->(0,0)
To determine this I have to use the continuity Rule (above) and first principle.
so
lim....f(0,h) - F(0)........(Imagine the divisor line there)
h->0.........h..............(and excuse the dots, spaces don't work)
lim.....[x(y+x^2) - 0 ] x [ 1 ]
h->0..[...x(x+y).......]....[ h ]
From here I'm a little stuck.
Do I cancel the x and solve the limit which result in infinity and therefore the function is not continuous at the origin OR put in the value of (0,h) for (x,y) and get the limit to equal zero?
ie.
....lim.....[0(h+0) - 0 ] x [ 1 ]
....h->0..[...0(0+h).....]....[ h ]
..=lim...........1
....h->0 .......h
Answers and Replies
HallsofIvy
41,833
956
I'm extremely confused. You say the problem is to determine whether or not the function is continuous at the origin and refer to the "continuity rule (above)" but I see no "continuity rule". what you have written:
(x,y)->(0,0)
has little to do with continuity.
You then seem to be using the definition of derivative to try to find the partial derivative with respect to y at (0,0)- I see no reason to want to do that and, if you really want to find it, I don't see why you have not set (x, y) equal to (0, 0) in the calculations from the start.
In any case, a function, f(x,y), is continuous at (0, 0) if and only if its limit, as (x, y) goes to (0, 0) is f(0,0).
I would recommend changing to polar coordinates: [itex]x= r cos(\theta)[/itex], [itex]y= r sin(\theta)[/itex] so [itex](xy+ x)^3= (r^2cos(\theta)sin(theta)+ r cos(theta))^3= r^3cos^3(\theta)(r sin(\theta)+ 1)^3[/itex] and [itex]x^2+ xy= r^2cos^2(\theta)+ r^2sin(\theta)cos(\theta)= r^2cos(\theta)(cos(\theta)+ sin(\theta))[/itex]. Since (x, y) is not (0, 0), r is not 0 so we can cancel the "r"s. The fraction reduces to
[tex]r\frac{cos^3(\theta)(rsin(\theta)+ 1)^3}{cos(\theta)(cos(\theta)+ sin(\theta))}[/tex]
That goes to 0 as r goes to 0, regardless of what [itex]\theta[/itex] is so the function is continuous at (0,0).
If your question was really whether or not the partial differentials are continuous at the origin, that's a different question.
Yea, I think I got a little confused since my book is a mess.
I had the question and answers messed up.
The continuity Rule should of been f(x) not df and in your exact words
"f(x,y), is continuous at (0, 0) if and only if its limit, as (x, y) goes to (0, 0) is f(0,0)."
I took that from another page in my book to see if the partial derivative was continuous. :S
1.To calculate the partial derivative at (0,0)
2.To show f(x,y) is continuous
1. I think I have to go to first principle to calculate the partial derivative.
2. Use the squeeze theorem to show the limit is zero then it's continuous.
( haven't done much on polar yet but I understand what you have done)
Thanks for your help.
Related Threads on Limit of a 3d function
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
