Limit of a function
Ipos Manger
31
Does lim x-> -2 (3x2+ax+a+3)/(x2+x-2) exist?
If so, find the limit.
I've tried factorizing the denominator to (x+2)(x-1), but then I don't know how to proceed on the exercise. I have seen that the limit exists when the numerator equals 0, but why is this (the denominator is also 0)? Does 0/0 exist at all?
Code:
Answers and Replies
8,278
What value of a would make the numerator zero when x = -2?
When both numerator and denominator are zero (i.e., the indeterminate form 0/0), it's usually because there is a factor in common between the top and bottom. Although not certain, there's a good chance that a limit exists.
Ipos Manger
31
a = 15.
So that means I just have to learn that by heart? Isn't there sort of a formal proof to test that? On the other hand, how do you know there's a factor in common between the top and bottom knowing that numerator and denominator are zero?
Thank you for your answer.
8,278
I don't think you need to memorize what I said - just be aware that if a limit has the form "0/0" you're not done yet. "0/0" is not a value - it is an indeterminate form, which means that you can't determine a value. All of the limits below have this form, but they have wildly different limit values.
$$\lim_{x \to 0}\frac {x^2}{x} = 0$$
$$\lim_{x \to 0}\frac {x}{x} = 1$$
$$\lim_{x \to 0^+}\frac {x}{x^2} = \infty $$
Note that in the 3rd limit, the two-sided limit doesn't exist, and that's the reason I am using the one-sided limit, the limit as x approaches zero from the right.
As far as a theorem goes, the only one that comes to mind is L'Hopital's Rule, which is applicable in cases with the indeterminate forms 0/0 and ±∞/∞.
verty
2,185
198
After you have factored the denominator, factor the numerator (or use Mark44's shortcut).
vela
Staff Emeritus
Education Advisor
15,563
2,203
There's a theorem that says that if p(x) is a non-constant polynomial and p(a)=0, then p(x) can be factored into p(x)=(x-a)q(x), where q(x) is another polynomial. In this problem both the numerator and denominator are polynomials; therefore, if they both equal 0 at x=-2, they have (x-(-2)) as a common factor.
chatnay
I'm sorry to hijack the thread, but does this mean that i have to learn as a general rule if the denominator is 0 (in the case of the limit), I have to solve the numerator for 0 and find the values that I can factorize? Thank you.
verty
2,185
198
I would say no, you don't have to do that. You must try to factorize the numerator IF it goes to 0.
Suggested for: Limit of a function
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
