Homework Help: Limit of a sequence
  1. Sep 18, 2007 #1
    Problem: Find the limit of the sequence
    [tex]a_{n}=\frac{n^{2}2^{n}}{n!}[/tex]
    My first thought was to say that
    [tex]0\leq \frac{n^{2}2^{n}}{n!} \leq \frac{x^n}{n!} [/tex]
    and by squeeze theorem, since [tex]\frac{x^n}{n!}=0[/tex] for all real x, my original limit must be 0 as well. Now all I need to do is prove that [tex]n^{2}2^{n} \leq x^n[/tex], which is where I'm stuck. Can anyone give me a hand? Thanks.
  3. Sep 18, 2007 #2
    EnumaElish
    Rearrange to n^2 < (x/2)^n.
  4. Sep 18, 2007 #3
    dynamicsolo
    What is x? Is [tex]0\leq \frac{n^{2}2^{n}}{n!} \leq \frac{x^n}{n!} [/tex] even true?
    You might break up the numerator and denominator into their respective factors and look at the ratios that are formed. I believe you'll find that some have specific values, others have finite values in the limit n-> inf. , and others go to zero in the limit.
  5. Sep 18, 2007 #4
    EnumaElish
    Not for any x and any n; but I think n^2 2^n < x^n as n --> +infinity.
  6. Sep 18, 2007 #5
    Sorry if it seems stupid, but I'm horrible at proofs, and am still coming up a bit short on proving [tex]n^2 \leq {(\frac{x}{2})}^n[/tex]
    I mean it seems fairly obvious that this is true to me, and more obvious still when I begin writing it out term by term for increasing n, but is this good enough to state it conclusively?
  7. Sep 18, 2007 #6
    Dick
    dynamicsolo's advice is a bit better. Write it as n*n*4*2^(n-2)/(n*(n-1)*(n-2)!). Does that suggest anything?
  8. Sep 18, 2007 #7
    I must be missing something obvious, because I've tried that as well with pretty much no success. :frown:
  9. Sep 18, 2007 #8
    dynamicsolo
    I'm suggesting that you write each factor in the numerator over a factor in the denominator and then consider each ratio you've formed. An example:
    (e^n)/(n!) = (e·e·...·e)/[n·(n-1)·...·3·2·1] ;
    there are n factors each in the numerator and denominator, so you can also write this as
    (e/n)·(e/n-1)·...·(e/3)·(e/2)·(e/1).
    In the case of our ratio, there are (n+2) factors in the numerator and only n in the denominator, so we will need to set aside two factors upstairs -- two of the 2s may be best. Now look at your ratio as a product of factors and recall that the limit of a product of terms is the product of the limits of the terms.
    Remember also that since we want the limit of the sequence a-sub-n, we are looking for the limit of this product as n-> infinity.
  10. Sep 18, 2007 #9
    Dick
    What are the limits of n/n, n/(n-1) and coup de grace 2^(n-2)/(n-2)!, I thought you said you knew x^n/n! -> 0. x=2 and if n->infinity, n-2->infinity.
  11. Sep 18, 2007 #10
    I got it. Thank you all, you've been a big help.
  12. Sep 18, 2007 #11
    dynamicsolo
    *thuds head with heel of hand, causing skull to emit dull, hollow sound*
    I just thought of something else: what is
    lim n->inf. of abs([tex]\frac{a_{n+1}}{a_{n}}[/tex])?
    We know the terms of this sequence are positive and you'll find this limit tends to zero. Thus the limit of the sequence is zero.
