Homework Help: Limit of a sequence
  1. Jan 18, 2017 #1
    Suppose [tex] a_{n}=\frac{n^2-2n+1}{2n^2+4n-1} [/tex]
    For each positive number [tex] \epsilon [/tex], find a number N such that:
    [tex] \mid a_{n} - L\mid < \epsilon [/tex] whenever n > N.
    2. Relevant equations
    3. The attempt at a solution
    [tex] \mid \frac{n^2 -2n + 1} {2n^2+4n-1} - \frac{1} {2} \mid < \epsilon [/tex]
    [tex] \mid \frac{3-8n} {4n^2+8n-2} \mid < \epsilon [/tex]
    Now I have no idea how to isolate the n so that I can find the N value. Any help appreciated.
    Thanks!
  3. Jan 18, 2017 #2
    PeroK
    Try some estimating.
    Can you fix your latex?
  4. Jan 18, 2017 #3
    Fixed it up.
    Estimating what exactly?
  5. Jan 18, 2017 #4
    PeroK
    Estimating is a technique, which no one seems to teach explicitly for evaluating limits. Let me give you an example and see if you can apply the idea to your case.
    Show that ##5n^2 + 3n + 133## tends to ##\infty## an ##n \rightarrow \infty##
    Estimating technique:
    For ##n > 1## we have ##n^2 > n## hence ##5n^2 > n##. So:
    ##5n^2 + 3n + 133 > 4n + 133 > 4n > n##
    Now, we can use a simple ##N## in the limit argument. Whereas, trying to find ##N## for the orginal quadratic would be messy.
  6. Jan 18, 2017 #5
    PeroK
    PS I think you've lost a factor of ##2## from the denominantor.
  7. Jan 18, 2017 #6
    Yes I definitely have, thanks.
  8. Jan 18, 2017 #7
    So it goes kinda likes this:
    For n > 1 we have [tex] n^2>n [/tex] hence, [tex] 2n^2>n [/tex] So:
    [tex] 2n^2+4n-1>5n-1>5n>n [/tex]
    And in a similar way:
    For n > 1 we have [tex] 3 - 8n > 3 - 8 = -5 [/tex] So:
    [tex] \mid \frac{-5}{n} \mid < \epsilon [/tex]
    and,
    [tex] n > 5 / \epsilon [/tex]
    Is that what you mean?
  9. Jan 18, 2017 #8
    PeroK
    First, you need to take that ##\epsilon## out of your working. That seems to be a common mistake to introduce ##\epsilon## into the inequality too soon. Second, your estimates have gone a bit wonky!
    Let me show you what I mean. You should leave out the ##\epsilon## for now and do:
    ##\mid \frac{n^2 -2n + 1} {2n^2+4n-1} - \frac{1} {2} \mid \ = \ \mid \frac{3-8n} {4n^2+8n-2} \mid \ < \ \mid \frac{8n} {4n^2+8n-2} \mid \ \dots##
    Note that the numerator is less than ##8n## and you need an over-estimate on the numerator and an underestimate on the denominator. But, your underestimate on the denominator can't be too crude, because ##8n/n## doesn't converge to 0. So, you need an estimate based on ##n^2## in this case.
    It's only when you've finished this algebra that you bring in ##\epsilon##. For example:
    Let ##\epsilon > 0 ## and take ##N > 1/ \epsilon## (or whatever you think you need from your calculations). Then ##n > N## implies:
    ##\mid \frac{n^2 -2n + 1} {2n^2+4n-1} - \frac{1}{2} \mid < \frac{1}{n} < \epsilon##
  10. Jan 18, 2017 #9
    Ok I think I get it now. Thanks for your help I'll do some more work on it.
  11. Jan 18, 2017 #10
    PeroK
    The simplest way to explain estimating is perhaps:
    ##|\frac{a(n)}{b(n)}| < |\frac{c(n)}{d(n)}|##
    Where ##|a(n)| < |c(n)|## and ##|b(n)| > |d(n)|## and ##c(n), d(n)## are some simple expressions in ##n## that reduce to something that can easily be shown to have a limit of ##0##.
Have something to add?
Draft saved Draft deleted
