Homework Help: Limit of f(x,y)
  1. Oct 3, 2012 #1
    Zondrina
    Let f(x,y) be defined :
    f(x,y) = 0 for all (x,y) unless x4 < y < x2
    f(x,y) = 1 for all (x,y) where x4 < y < x2
    Show that f(x,y) → 0 as (x,y) → 0 on any straight line through (0,0). Determine if lim f(x,y) exists as (x,y) → (0,0).
    2. Relevant equations
    Polar co - ordinates maybe?
    3. The attempt at a solution
    Pretty confused with this one actually. Not sure where to start.
    I want to show f(x,y) → 0 as (x,y) → 0 on any straight line through the origin. So would I pick lets say y=x.
    Then f(x,x) = I'm not sure, having trouble with the inequalities.
  3. Oct 3, 2012 #2
    jbunniii
    Is the following true or false? [itex]x^4 < x < x^2[/itex]
  4. Oct 3, 2012 #3
    LCKurtz
    No, you don't want polar coordinates on this. In the xy plane draw your two curves ##y=x^4## and ##y=x^2##. Note in your picture which areas have f(x,y) = 0 and which have f(x,y)=1. Then draw lines ##y=mx## for various ##m##. You should be able to see graphically why f(x,y) → 0 along those lines as (x,y)→ (0,0). Then can you find a path where it doesn't go to zero?
  5. Oct 3, 2012 #4
    Zondrina
    This is false.
    Also @ LC, I used wolfram to plot the curves for me http://www.wolframalpha.com/input/?i=plot+y%3Dx^4+plot+y%3Dx^2
    I understand what you mean geometrically, I can't find any line y=mx where the graph does not go through the origin.
    Its the analytical portion I'm confused about.
  6. Oct 3, 2012 #5
    LCKurtz
    Of course the lines y=mx go through the origin. It is the value of f(x,y) on the line and near (0,0) that you are interested in. Did you observe where in the plane f = 1 and f = 0 on your picture like I suggested?
  7. Oct 3, 2012 #6
    SammyS
    Staff Emeritus
    Where does the line, y = mx, intersect the parabola, y = x2 ?
  8. Oct 3, 2012 #7
    Zondrina
    Okay i think i got it.
    So any line y=mx we draw will not be fully contained in the region x^4 < y < x^2.
    So lim f(x,mx) as (x,y) -> (0,0) = 0 for all (x,y).
    Now considering the graph of y=x^3, the path of x^3 is contained within the region x^4 < y < x^2.
    So lim f(x,x^3) as (x,y) -> (0,0) = 1 for all (x,y).
    Since the two limits are not the same the limit doesn't exist?
  9. Oct 3, 2012 #8
    LCKurtz
    That's the idea. You have a bit of work to do to actually prove it. Do you understand why Sammy asked where y=mx intersects y = x2?
  10. Oct 3, 2012 #9
    Zondrina
    They only intersect at the origin (depending on m). Not sure why that's relevant though.
  11. Oct 3, 2012 #10
    SammyS
    Staff Emeritus
    Check your algebra. (The only case of one solution is for m=0.)
    [itex]\displaystyle \text{If }x^2=mx\,,\text{ then }\ \ x^2-mx=0 \quad \Rightarrow\quad(x-m)x=0\ .
    [/itex]
    What are the two solutions to that?
  12. Oct 3, 2012 #11
    LCKurtz
    Think about y = mx for m really small and positive, so the line is very very close to horizontal. That line is going to get in between the two curves and f(x,y) will equal 1 in there and be close to the origin. How do you know it doesn't stay between them as x approaches 0? And that gives a problem with the limit being 0 along all straight lines through the origin. That is the crux of this problem.
