Homework Help: Limit of integral
  1. May 23, 2010 #1
    are there any rules on how to find the limit of an integral equation?
    for example,
    find x such that the limit as y(x) tends to infinitiy of the integral equation equals 1
    [tex]lim \int_0^x \frac{1}{y(t)-y(x)}dt=1[/tex]
    2. Relevant equations
    3. The attempt at a solution
    Im not sure how to do this, can i simply swap the limit sign with the integral sign?
    Thanks in advance.
  3. May 23, 2010 #2
    gabbagabbahey
    Huh?:confused:
    [tex]\lim_{y(x)\to\infty}\int_0^x\frac{dt}{y(t)-y(x)}=0[/tex]
    For all values of [itex]x[/itex], so I'm not sure what you mean here.
  4. May 23, 2010 #3
    why does the limit = 0
    what if we had t in the numerator instead of 1?
  5. May 23, 2010 #4
    I think you're asking:
    Let:
    [itex]\lim_{x\to a} y(x)=\infty[/itex]
    is there a function y(x) such that:
    [itex]\lim_{x\to a}\int_0^x \frac{1}{y(t)-y(x)}dt=1[/itex]
  6. May 23, 2010 #5
    no, i mean, i need to find an 'x'.
    I agree that the integrand is 0 (if y tends to infinity)
    but what if we have
    [tex]\lim_{y(x)\to\infty}\int_0^x\frac{(x-t)^{-1}dt}{y(t)-y(x)}=1[/tex]
    can we find an x such that the limit is 1?
  7. May 23, 2010 #6
    If you are fixing x, how can y(x) tend to infinity?
  8. May 23, 2010 #7
    because i need to find an x, say x* such that as y(x*) tends to infinity, the limit is 1
  9. May 23, 2010 #8
    y(x*) is some number. It doesn't make sense to say that a number tends to infinity. Perhaps I'm misunderstanding the question?
  10. May 23, 2010 #9
    sorry, i think im confusing things.
    forget y(x*).
    I want to find x such that
    so y(x) is just a function depending on a variable x. then, after i found the limit (in terms of x), i want to solve the equation for x...
    am i making sense?
  11. May 23, 2010 #10
    Would the following interpretation be correct:
    Look for x* such that
    [tex]
    \lim_{x \rightarrow x^*} y(x) = \infty
    \quad\text{ and }\quad
    \lim_{x \rightarrow x^*} \int_0^x \frac{(x-t)^{-1}dt}{y(t)-y(x)} = 1,
    [/tex]
    where we always approach x* from the direction of 0.
    But even if this isn't the right interpretation, it seems important to know what y(x) is as well.
  12. May 23, 2010 #11
    yes, this is the right interpretation.
    is it possible to find x* without knowing what the function is?
  13. May 23, 2010 #12
    gabbagabbahey
    Are you sure your integrand isn't [tex]\frac{y(t)-y(x)}{t-x}[/tex] instead?
  14. May 23, 2010 #13
    yes, im sure.
    would it be easier if it was?
  15. May 23, 2010 #14
    In addition, I don't see how to find x* without knowing the function. I mean, x* appears at a vertical asymptote, but different functions have different asymptotes.
  16. May 23, 2010 #15
    lets assume it has a vertical asymptote.
    would we be able to find x* then?
  17. May 23, 2010 #16
    Evaluate the improper integral at most at two candidates for x*, one to the left and right of zero. Then, if one of those equals 1, you're good. I don't know another way.
