Limit of Sequence: Help Solving Equation
In summary, the person is asking for help with a limit and is confused about how to solve it. They are told that the limit should be equal to e/2 and that using series will help them prove it.
twoflower
368
Hi all,
I can't move with this limit:
[tex]
\lim_{n \rightarrow \infty} n \left( \left( 1 + \frac{1}{n} \right)^{n} - e \right)
[/tex]
Could someone help me please? Or some hint...
But no l'Hospital please.
Thank you
Find out what
[tex]
\lim_{n \rightarrow \infty} \left( 1 + \frac{1}{n} \right)^{n}
[/tex]
is. It should all be clear from then on.
Well I know it is equal to e, but then
[tex]
\lim_{n \rightarrow \infty} n \left( e - e \right) = \lim_{n \rightarrow \infty} n \left ( 0 \right) = 0.\infty
[/tex]
Which is undefined...
Are you opposed to using the series expansions of log(1+x) and e^x? You can re-write the (1+1/n)^n term as e^(n*log(1+1/n)). Use the Taylor series for log(1+x), at least 2 terms +remainder. Then you can factor out an e and use the series for e^x, (2 terms+remainder here as well), and that will do it.
If you are opposed to using series but have learned them, it's probably possible to modify the above into a squeeze limit type of proof. If you haven't learned Taylor series yet, I'll have to think of a more elementary method, though it will probably be a thinly disguised version of the above.
Thank you shmoe, maybe this limit is really supposed to be solved using Taylor series, because it is from sample calculus test we're going to take, but as I see in sylabus, we'll learn Taylor series before the test. It confused me, because the sequences are already behind us and I thought I should already be able to solve any limit of sequence...
[tex]
[/tex]
you cannot sub in the value for e in between the limit like that
i wonder if this will work though
split the limit so you have the limits of n(1-1/n)^n and n e subtracted from each other.
now the limit of n (1-1/n)^n is infinity while the limit of n E is also infinity
however the first one converges to e more slowly that E already does
so n E >n(1-1/n)^n and the limit is negative infinity
The limit should be -e/2...
check what you entered into maple/mathematica/matlab... it isn't -e/2, it is -infinity
No, this won't work. You're essentially saying infinity-infinity=-infinity because the first infinity is getting there slower. This is bunk. An indeterminate infinity-infinity limit form can potentially equal anything we like(-e/2 is correct in this case, done by hand with the method I suggested).
twoflower-series is likely what's intended then. I can't see another way that isn't unnecessarily complicated.
twoflower said:
Hi all,
[tex]
[/tex]
If you can show that
[tex]-\frac{e}{2n} - \epsilon_1(n) \leq \left( 1 + \frac{1}{n} \right)^{n} - e \leq -\frac{e}{2n} + \epsilon_2(n)[/tex]
Where [itex]\epsilon(n)[/itex] is some expression that goes to zero faster than
[itex]\frac{1}{n}[/itex] then you're set, so perhaps you should look at the convergence of [itex]\left( 1 + \frac{1}{n} \right)^{n} [/itex]
I tried it now. Maple gives -e/2
Nate, do you have a simple method in mind for those inequalities?
The obvious approach to me involves some bounds on log(1+x) and e^x that I would prove using series.
Ok, so you say guys that the most natural way to find this limit is to use Taylor series. If it's right, I will skip this one. Or does anyone have simplier approach to show?
1. What is a limit of a sequence?
The limit of a sequence is the value that the terms of the sequence approach as the number of terms increases. It is the value that the terms get closer and closer to, but may never actually reach.
2. How is the limit of a sequence calculated?
The limit of a sequence is typically calculated by finding the pattern in the terms of the sequence and then using a mathematical formula or algorithm to determine the value that the terms approach as the number of terms increases.
3. Can the limit of a sequence be infinite?
Yes, the limit of a sequence can be infinite if the terms of the sequence continue to increase or decrease without approaching a specific value.
4. What is the significance of finding the limit of a sequence?
Finding the limit of a sequence can help us understand the behavior and trends of a sequence as the number of terms increases. It also allows us to make predictions about the future terms of the sequence.
5. What are some real-life applications of finding the limit of a sequence?
Limit of sequence is commonly used in fields such as physics, economics, and engineering to model and predict the behavior of systems. It is also used in computer science for algorithm analysis and optimization.
  • Set Theory, Logic, Probability, Statistics
  • Math POTW for University Students
