Limit of
  • Thread starter dichotomy
i've to show (as part of a bigger assignment) that
a^n/p(n), where p is any polynomial and a>1, tends to infinity as n does. i've proved that:
a^n/n^k
does so, but i'm not sure how to extend this to a complete polynomial such as
(c1)n+(c2)n^2+(c3)n^3...
thanks for any help
NB: edited
matt grime
9,394
You've used a for two different things; and forgotton a condition on the first a.
Remember the triangle inequality:
|x+y| <= |x|+|y|
that will help.
24
right...well all i can think of at the moment is changing (n^k) to (n+b)^k and prove that it works for that - however i don't think thats valid since (i don't think) every possible polynomial can be created by such an expansion.
i've not a clue where to start with the triangle inequality
StatusX
2,563
Try proving the reciprical tends to zero, then you can just add different powers of n in the numerator.
24
proving the reciprocal goes to zero is exactly how i did a^n/n^k.....
but i didn't think you could just add terms in various powers of n and expect the same result as a^n/n^k (or its reciprocal) without proving it?
also, i think all that is needed is the ratio test for convergence (of the reciprocal) however if I use this when I replace n^k with (b+n)^k (to create the polynomial), i end up with series within series, and i'm not sure what to do with that.
(The ratio test is also what i used for a^n/n^k)
Gib Z
3,344
The nth root test, where you take the nth root as n approaches infinity.
For the numerator, you get (a^n)^(1/n) as n approaches infinity. The powers equate leaving us with just a. The denominator, it becomes p(n)^(1/n) as n approaches infinity. so in the end we get a*p(n)^n. As n approaches infinity, the polynomial will as well. So the result of our nth root test is more than 1. That means it does not converge, and therefore diverges. As n approaches inifinity, both a^n and p(n)^n will be positive, meaning it diverges positively, to infinity.
Note: I didnt use that triangle inequality that matt grime posted, which makes me think i may have done something wrong lol, matt grimes always right...
matt grime
9,394
There is always more than one way to skin cat. However, you have asserted that
a/p(n)^{1/n} = a*p(n)^n
which is not correct. Your 'proof' also works for a=1, which is unfortunate, as 1/p(n) tends to zero as n tends to infinity.
matt grime
9,394
The hint was to use the triangle inequality. I don't see anyone doing that. Try to use the triangle inequality to go from studying p(n) to a k*n^r, where k is a constant and r is the degree of p(n) (and no, k is not the coeffeicient of n^r in p(n)).
matt grime
9,394
That is what the triangle inequality will let you do - You can replace
[tex] | b_r n^r + b_{r-1}n^{r-1} + \ldots b_0|[/tex]
with something larger. Notice that n^r > n^{r-1} for n>1, r>2.
24
do you mean:
[tex]| b_r n^r + b_{r-1}n^{r-1} + \ldots b_0| \leq |n^r + n^r + n^r + \ldots \mbox{(to the extent of k)}|[/tex]
which only is true if
[tex]b_{r-s} < n^s \mbox{ and } \ k=r[/tex] where s=1,2,3...
but the coefficients of [tex]n^{r-s}[/tex] are going to be much smaller than any possible value of [tex]n^{r-s}[/tex] once n approaches infinity, such that the first condition can be ignored?
nb: only just started with latex so bear with me...
matt grime
9,394
What are you using k to mean? Not what I used it to mean.
Gib Z
3,344
ahh damn i knew i must have stuffed something up, couldnt have been that simple that someone else didnt see...ahh o well
1,424
You are talking about orders of magnitude. First, we prove that a^x/ x tends to infinity as x increases beyond all bounds. Consider the function f(x) = log [a^x/ x] = x log a - log x. Surly if we prove that if f(x) goes to infinity, we prove that a^x/ x goes to infinity as well. Now let us consider f'(x) = log a - 1/x. Now for x>c, we have f'(x)>1/2 log a. Let us define g'(x) = 1/2 log a. By the principles of integral,
f(x) - f(c) > g(x) - g(c).
f(x) - f(c) > (x-c)*1/2 log a
f(x) > (x-c)*1/2 log a + f(c)
Clearly the right expression goes to infinity as x increases. Thus we have proved that f(x) goes to infinity as well.
Now we have a polynomial of power n and a x^n+1. If p(x) remains positive past a certain point, the expression x^n+1/p(x) goes to infinity - this can be proven using Hopital's law. Now
a^x/p(x) = [a^x/x^n+1]*[x^n+1/p(x)].
We need only to prove that a^x/x^n+1 has a positive limit or is unbounded in order to prove the statement that a^x/p(x) goes to infinity as x increases. We consider, the n+1 th root of the expression that is,
a^x/n+1 / x
This can be rewritten as
1/n+1 * [a^x/n+1 / (x/n+1)]
Putting x/n+1 = y, we have
1/n+1 * [a^y / y]
As was shown, a^y/y goes to infinity as y increases. Thus, the n+1 th root goes to infinity and a^x/x^n+1 goes to infinity as well. Finally, a^x/p(x) goes to infinity.
Related Threads for: Limit of
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
Hot Threads
