Solving a Limit: Evaluating limx->0 (e^x - 1- x - (x^2/2))/x^3
  • Thread starter lab-rat
  • Tags
    E^x Limit
In summary, the limit of (e^x - 1- x - (x^2/2))/x^3 as x approaches 0 is 1/6. This can be solved using l'Hopital's rule multiple times, and the final result is (e^x)/5.
lab-rat
44
Evaluate limx->0 (e^x - 1- x - (x^2/2))/x^3
I can't remember how to solve this limit. Do I need to evaluate each part seperately? I plugged in the 0 to find that the limit does exist. I just can't seem to figure out what to do next.
Why not use l'Hôpital's rule?
Or use the Taylor series of the exponential function.
If I use l'Hopital's rule won't I end up with 3x^2 at the bottom?
You will want to use l'Hopital multiple times.
The limit of a sum is the sum of limits - Lim[a+b]=Lim[a]+Lim
Then as everyone before has said, you're going to want to use l'hopitals rule for the last term
I used L'Hopital's rule three times and ended up with limx->0(e^x)/5
Is this correct? It still gives me 0 on top.
Here is how I did it in case it might help
lim->0 (e^x)' - 1' - x' - (x^2/2)' /x^3'
= lim->0 (e^x' - 1' - x')/ 3x^2'
= lim->0 (e^x' - 1') / 5x'
= lim x->0 (e^x) /5
Very close, but look at your second to thrid line in the denominator.
What is: $$\frac{d}{dx}(3x^{2})$$
After you fix that, evaluate it at 0.
[tex]
\lim_{x\to 0}~ e^{x}
[/tex] should not be 0.
Thanks!
It should be 6x right?
So is 1/6 the correct answer?
1/6 is the correct result.
What does the limit represent?
The limit represents the value that a function approaches as its input approaches a certain value, in this case, as x approaches 0.
Why is it important to solve limits?
Solving limits allows us to understand the behavior of a function at a specific point and make predictions about its behavior near that point.
What is the general process for solving a limit?
The general process for solving a limit involves simplifying the expression as much as possible, plugging in the value the function is approaching, and evaluating the resulting expression.
How do you solve the given limit?
To solve limx->0 (e^x - 1- x - (x^2/2))/x^3, we can use L'Hopital's rule to rewrite the expression as limx->0 (e^x - 1- x - (x^2/2))/(3x^2). Then, plugging in 0 for x, we get 1/6 as the final answer.
What is the significance of the given limit in mathematics or science?
This limit is significant in calculus as it helps us understand the concept of derivatives and their applications in various fields of science and engineering. It also plays a crucial role in solving differential equations and determining the rate of change of a function at a particular point.
