Limit question
[tex]
\lim _{x->+\infty} (x+2)^{\frac{2}{3}} -(x-2)^{\frac{2}{3}}
[/tex]
i get infinity - infinity
its undefined
tiny-tim
25,789
242
Hi transgalactic! :smile:
It's easier to read if you write …
[tex]\lim _{x->+\infty} (x+2)^{2/3} -(x-2)^{2/3}[/tex] :wink:
eek! you're not allowed to do that! :eek:
Hint: write it [tex]\lim _{x->+\infty} x^{2/3}\left((1 + 2/x)^{2/3} -(1 - 2/x)^{2/3}\right)[/tex] :wink:
32,107
3,993
[tex]
[/tex]
its undefined
infinity - infinity is one of several indeterminate forms. None of them are ever an answer.
djeitnstine
[tex]
[/tex]
its undefined
A hint when doing limits, just think about what happens when the number gets REALLY big. Eventually does it matter that you add 2 or subtract 2 from say...10000000000000000? It will approximate to [tex]x^{\frac{2}{3}}-x^{\frac{2}{3}}[/tex] in the end...
Also the result is the same as tinytim's =]
so i get 0*infinity
its not defined either
tiny-tim
25,789
242
(x-2)2/3 is less than (x+2)2/3 so each time the x gets larger a larger sum is in (x-2) than(x+2) so it goes down... to minus infinity.
djeitnstine
Noo that is also not the result! Read my post and tinytim's again
When in doubt graph it!
HallsofIvy
821
When tiny-tim says "expand the brackets first" I believe he is referring to the generalized binomial expansion. And you should only need the first few terms.
32,107
3,993
Another approach is to multiply the original expression by 1 like so:
[tex](x + 2)^{2/3} - (x - 2)^{2/3} \frac{(x + 2)^{4/3} + (x + 2)^{2/3}(x - 2)^{2/3} + (x - 2)^{4/3}} {(x + 2)^{4/3} + (x + 2)^{2/3}(x - 2)^{2/3} + (x - 2)^{4/3}}[/tex]
This looks pretty complicated, but it's based on a relatively simple idea: that (a - b)(a2 + ab + b2) = a3 - b3.
After using this technique, the numerator can be simplified to a single term, and the limit of the whole expression can be found without much trouble.
djeitnstine
Why need to get so complicated :S this is quite a simple problem. Quite frankly the answer is 0. There is an asymptote in the graph tending towards 0 as x increases towards positive infinity. Now which result out of mine or tinytim's did not explain this?
I can re iterate of course "Eventually does it matter that you add 2 or subtract 2 from say...10000000000000000? It will approximate to [tex] x^{\frac{2}{3}}-x^{\frac{2}{3}}[/tex] in the end..." which of course is always tending towards 0...
32,107
3,993
Agreed that this is a simple problem, and that the limit is 0. Tiny Tim's approach is superior to mine in its simplicity. Your approach, using a computer-generated graph, is useful for gaining understanding about the behavior of this function, but that's about it. It is well-known that computers don't produce exact results, because of the limited precision they use in their calculations, and especially so in raising to fractional powers. And in some cases, they can produce results that are incorrect (e.g., the earlier Intel Pentium math coprocessors back in 1992 or so). You also said that for large x, x + 2 was about the same as x - 2. This is correct, and is helpful in understanding, but it should be said in mathematical terms. Otherwise, it's akin to arm-waving, IMO.
My approach is different from, and slightly more complicated, than Tiny Tim's. But so what? Multiplying by a factor to produce a difference of cubes isn't all that complicated, and the intent was to show another method of approach that might be useful in other problems.
The more tools you have to work with, the more problems you're equipped to solve.
djeitnstine
Well I do understand that your method was valid, however I believe when helping someone whom is slightly confused the simplest approached should be used. Don't you agree?
32,107
3,993
I agree that the simplest approach should be shown first. Then you can show other approaches, just as was done in this thread.
Want to reply to this thread?
"Limit question" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Top Threads
