Differentiability of Functions with Two Real Variables
In summary, if a function is differentiable at a point (a, b), then there exists a linear mapping between the variables that will give the derivatives of the function at (a, b) in the desired direction.
freya81
Am mainly stuck on parts c) and d) but thought i'd put in the other questions as an aid
2. a) Define what it means to describe a function f of two real variables as differentiable at (a, b)? Define (as limits) the partial derivatives df/dx and df/dy at
(a, b) and prove that if f is differentiable at (a, b) then both these partial derivatives exist.
b) Prove from the definition in a) that the function f defined by f(x,y) =xy(x+y) is differentiable at every point of it’s domain
c) If g(x, y) = xy prove that g is not differentiable at (0, b) for any non- zero value of b
d) Prove that the function g of part c) is differentiable at all points (a,b) for which a is not zero and at the origin (0,0)
it this correct
2. a) f is differentiable at (a,b) iff there exists a linear mapping L such that lim((f(a+h,b+k)-f(a,b)-L(h,k))/|(h,k)|,(h,k)->(0,0))=0. ∂f/∂x(a,b)=lim((f(a+h,b)-f(a,b))/h,h->0), and ∂f/∂y(a,b)=lim((f(a,b+k)-f(a,b))/k,k->0).
does L=grad f; that is, L(h,k)=(∂f/∂x,∂f/∂y).(h,k)=h*∂f/∂x+k*∂f/∂y.
what do i do next?
L is the derivative of f in the direction of the vector <h,k> (i.e. from (a,b) to (a+h,b+k). In a given coordinate system, L is the gradient of f, evaluated at (a,b), dot the vector <h,k>. Note, however, that L, as a linear mapping, exists without a coordinate system. The partial derivatives, of course, depend upon the coordinate system. It is also true, by the way, that a function can have partial derivatives at a point and not be differentiable there.
For b, c, and d, about all I can say is "do it"! You can find the partial derivatives of each so you know what L is for each one. Put the functions and L into the formula in a and do the algebra.
1. What is the definition of a limit?
The limit of a function at a certain point is the value that the function approaches as the input approaches that point. In other words, it is the value that the function "gets closer and closer to" as the input gets closer and closer to the specified point.
2. How do you determine if a function is continuous at a point?
A function is continuous at a point if the limit of the function at that point exists and is equal to the value of the function at that point. In other words, the left-hand limit and right-hand limit at that point must both exist and be equal to the function value at that point.
3. What is the difference between a removable and non-removable discontinuity?
A removable discontinuity occurs when a function has a hole or a gap at a certain point, but can be made continuous by redefining the function at that point. A non-removable discontinuity, on the other hand, cannot be made continuous by redefining the function at that point and often occurs when there is a vertical asymptote.
4. How do you determine if a function is differentiable at a point?
A function is differentiable at a point if the derivative of the function exists at that point. This means that the tangent line to the graph of the function at that point is well-defined and has a non-zero slope.
5. What is the relationship between continuity and differentiability?
A function must be continuous at a point in order for it to be differentiable at that point. This means that if a function is not continuous at a point, it cannot be differentiable at that point. However, a function can be continuous at a point without being differentiable at that point.
