Homework Help: Limits and functions
  1. Nov 4, 2013 #1
    removable discontinuity
    the following function
    f(x)=(4-x)/(16-x^2)
    is discontinuous at???
    i got at -4 but some of my friends say its 4, -4
    how is that possible
  3. Nov 4, 2013 #2
    jbunniii
    Is the function even defined at ##x = \pm 4##?
  4. Nov 4, 2013 #3
    well thats what u have to find
    where is it discontinuous
    i have an exam on this but its not clear yet to me
  5. Nov 4, 2013 #4
    jbunniii
    Discontinuous doesn't mean the same thing as undefined. Go back to the definition of continuity: can a function be continuous at a point if it is not defined at that point?
  6. Nov 4, 2013 #5
    well basically we just have to use the function and find the points where its disconitinuous
    i.e in the graph there is a hole or a jump
    check here
    http://www.dummies.com/how-to/content/how-to-determine-whether-a-function-is-discontinuo.html
  7. Nov 4, 2013 #6
    jbunniii
  8. Nov 4, 2013 #7
    but if u factorize the denominator and cancel you will only get -4 as a point of discontinuity
    try it yourself
  9. Nov 4, 2013 #8
    HallsofIvy
    Are you saying that the difficulty is that you do not know what "continuous" means? Didn't It occur to you to look up the definition?
    A function, f, is continuous at x= a if and only if:
    (1) f(a) exists
    (2) [itex]\lim_{x\to a} f(x)[/itex] exists
    (3) [itex]\lim_{x\to a} f(x)= f(a).
    For what values of x is at least one of those NOT true? (Look specifically at (1)!)
  10. Nov 4, 2013 #9
    but if u factorise it and cancel the common
    you only get -4 as the point of discontinuity
  11. Nov 4, 2013 #10
    jbunniii
    Note that
    $$\frac{4-x}{16-x^2}$$
    and
    $$\frac{1}{4+x}$$
    are not the same function. They are equal for ##x \neq 4##, but the first function is undefined (hence discontinuous) at ##x=4## whereas the second is defined and continuous at ##x=4##.
    Therefore the first function has what kind of discontinuity at ##x=4##?
  12. Nov 4, 2013 #11
    jbunniii
  13. Nov 4, 2013 #12
    i guess it has a removable one right??
  14. Nov 4, 2013 #13
    jbunniii
    That's right. After you remove it by canceling the common factor in the numerator and denominator, the result (second function I listed above) is continuous at that point.
    Now what about ##x = -4##? You correctly determined that it is discontinuous there. What kind of discontinuity is it?
  15. Nov 4, 2013 #14
    non removable
    but do they both count as discontinuities
  16. Nov 4, 2013 #15
    jbunniii
    Sure. A removable discontinuity is still a discontinuity. As your link describes it, you can think of it as a "gap" in the graph of the function at ##x = 4##. You can fill the gap by removing the common factor so the denominator will be defined at ##x=4##.
  17. Nov 4, 2013 #16
    thanx alot man
    i owe you one
    wish me luck for tomorrows exam
  18. Nov 4, 2013 #17
    jbunniii
    Absolutely, good luck!
Have something to add?
Draft saved Draft deleted
