Homework Help: Limits and infinity problem
  1. Aug 21, 2010 #1
    Hi, I need to figure out what happens to this equation in the limits
    [tex] E = \frac{1}{4\pi\epsilon_0} \frac{2\lambda L}{z \sqrt{z^2+L^2}} [/tex]
    in the two different cases
    that z>>L
    and when L -> infinity
    (note this equation was derived from finding the electric field da distance z, above the midpoint of a straight line segment of length 2L, which carries a uniform line charge of [tex] \lambda [/tex]
    3. The attempt at a solution
    for the case when, z>>L I can see how the L term becomes insignificant in the square root on the bottom,
    and so the equation would just become
    [tex]\frac{1}{4\pi\epsilon_0} \frac{2\lambda L}{z^2} [/tex]
    but for the case when L approaches infinity, what do I do???
    the squareroot of a L^2 +z^2 == L?
    does that mean the L can just be canceled out?
    [tex] \frac{1}{4\pi\epsilon_0} \frac{2\lambda L}{z *L} [/tex]
    and the equation becomes?
    [tex] \frac{1}{4\pi\epsilon_0} \frac{2\lambda}{z} [/tex]
    i'm not sure if i'm allowed to since the Z was the distance from the midpoint of the line,
    the first one makes sense since it just becomes a point charge of 2lambda L
    but the second case, i'm not too sure what it becomes
  3. Aug 21, 2010 #2
    lanedance
    Re: Limits
    consider the form of the field produced by an infinite conductor, which should agree with your 2nd result
  4. Aug 21, 2010 #3
    lanedance
    Re: Limits
    it helps to re-write the expression in the following form so it is clear when you take the limit
    first as follows
    [tex] E
    = \frac{\lambda}{ 2 \pi\epsilon_0} \frac{ L}{z^2} \frac{1}{\sqrt{1+\frac{L^2}{z^2}}}
    \approx \frac{\lambda}{ 2 \pi\epsilon_0} \frac{ L}{z^2} (1-\left(\frac{L}{z}\right)^2 + O\left(\frac{L}{z}\right)^4)
    [/tex]
