Rules for Moving Limits Inside Definite Integrals
In summary, if you want to take the limit of a definite integral inside the integration sign, you can do so if the function includes a constant. Otherwise, it is more annoying to try and get the same answer.
gonzo
277
What are the rules for when you can and can not move the limit of a definite integral inside the integration sign?
For example, if I have a definite integral of a function f(z) and the function includes a constant k, and I want to take the limite of the definite integral as k goes somewhere interesting, under what circumstances can I take the limit first of f(z) before interating and get the same answer (if ever)?
Note that this limit has no affect on the limits of integration.
For example:
[tex]
\lim_{r\to\infty} \int_{0}^{2\pi}{e^{r\alpha}e^{ix\alpha} \over 1+e^re^{ix}}dx
[/tex]
for [itex]0<\alpha<1[/itex]
If I can move the limit inside the integral, it is is easy to show that this is 0. Otherwise it is more annoying (and I am pretty the answer here has to be zero).
You've probably seen swapping the order of a limit and an integral in the real case? You can apply the relevant theorems, uniform convergence will do the trick (for your example).
Alternatively for this example, you can try to bound the absolute value of that integral by something that tends to 0 as r->infinity (you'd do this anyways trying to prove uniform convergence).
Actually, that's part of the problem, I haven't seen this in the real case, or at least I don't remember it.
Can you point me to the relevant theorems? Or at least give me a quick overview or summary?
To be clear, I understand the idea of uniform convergence in general, and I sort of understand the second thing you said for a way to show it in this case, but I was wondering about general theorems, which I haven't seen. And in case it wasn't clear in this example, x itself is real.
This will be in any real analysis text, you've probably seen integrating power series term by term? It's a consequence of uniform convergence, and a more general theorem is usually proven first.
If you have a sequence [tex]f_n[/tex] of integrable (real valued) functions on [a,b] that converge uniformly to f on [a,b] then f is integrable and you have
[tex]\lim\limits_{n\rightarrow\infty}\int_a^b f_n(x)dx=\int_a^bf(x)dx[/tex]An integral of a complex function can be viewed as the integral of the real part plus the integral of the imaginary part and you can apply the above.
If you want to talk about integrals on infinite intervals then uniform convergence won't be enough. there are various criterea that allow interchanging the limit and the integral, see the Lebesgue dominated convergence theorem for example.
I understand what you wrote above, but I don't really see how it applies to my issue. Your limit example is with regard to the number of terms in a series, which seems to me to be different, even if you talk about expanding a funciton with a power series.
I'm also sure I can probably solve my particular by a more detailed analysis, but I was hoping that there would be some useful theorems about when specifically you can move the limite inside the integral, since that would greatly simplify things.
I assume this is dependent on some quality of the function being integrated, since a casual look shows that this works for simple functions.
I would like to know if there is a simple set of conditions on a function being integrated that are sufficient for this to be true.
If you can prove the version I gave for sequences of functions, you should see the result is true for a family of functions f_r(x) converging to f(x) uniformly in r, a real variable.
to prove the result in my last post (a simpler version, let's assume we know f is integrable), for any [tex]\epsilon>0[/tex] you can find an integer N such that n>=N implies [tex]|f_n(x)-f(x)|<\epsilon/(b-a)[/tex] for all x in [a,b]. Then:
[tex]\left|\int_a^b f_n(x)dx-\int_a^bf(x)dx\right|\leq\int_a^b|f_n(x)-f(x)|dx\leq\epsilon[/tex]
So the limit of the integrals converges to the integral of the limits.
If you have a family of functions parameterized by real numbers r that converges uniformly, just change all the n's to r's and N's to R's and the proof works just fine.
Okay, let me see if I'm following everything. We'll use my example.
Let:
[tex]
f={e^{r\alpha}e^{ix\alpha} \over 1+e^re^{ix}}
[/tex]
Then if we can show that f uniformly converges to 0 as r goes to infinity over the domain of integration then we can move the limit inside the integral, which in this case shows that the integral also goes to 0.
Since we are working with complex number, we want to show that the absolute value of f converges uniformly to 0.
This gives us:
[tex]
|f|=\sqrt {e^{r\alpha} \over {1+2e^rcosx+e^{2r}}}
[/tex]
And then we have:
[tex]
|f| \leq \sqrt {e^{r\alpha} \over {1-2e^r+e^{2r}}}
[/tex]
This last expression is independent of x, and converges uniformly to 0, so the absolute value of f must also do so, which means our integral is 0.
Is that about what you meant?
Your numerator shouldn't be squared, otherwise that's fine.
You don't have to bother multiplying by the conjugate though, the absolute value of the numerator is just e^(alpha*r). The denominator's absolute value is >= e^r-1 by the triangle inequality, that same as what you have but less big square root signs.
Sure, that was sloppy of me, but I was more concerned with getting the general idea correct. Which from your response I assume it is.
Thanks for your help.
1. What is the purpose of moving limits inside definite integrals?
Moving limits inside definite integrals allows us to evaluate the integral more easily by simplifying the integrand. This can lead to a more efficient and accurate calculation of the integral.
2. When can limits be moved inside definite integrals?
Limits can be moved inside definite integrals when the integrand is continuous and the limits of integration are constants. Additionally, the integral must exist at all points between the original and new limits.
3. What are the steps for moving limits inside definite integrals?
The steps for moving limits inside definite integrals are as follows:
  1. Write the integral with the original limits of integration.
  2. Simplify the integrand using algebraic techniques.
  3. Write the new limits of integration in terms of the original limits.
  4. Replace the original limits with the new limits.
  5. Evaluate the integral with the new limits.
4. Are there any special cases when moving limits inside definite integrals?
Yes, there are a few special cases when moving limits inside definite integrals. One case is when the integrand contains a variable in the limits of integration. In this case, the variable must be kept in the integral until the final step. Another case is when the integrand is a piecewise function. In this case, the limits must be adjusted accordingly for each piece of the function.
5. What are the potential errors when moving limits inside definite integrals?
The most common error when moving limits inside definite integrals is changing the sign of the integral. This can occur if the limits are not properly adjusted or if the integrand contains negative terms. Other potential errors include forgetting to replace the original limits with the new limits or incorrectly simplifying the integrand.
  • Calculus
