Homework Help: Limits of Integration
  1. Jan 22, 2014 #1
    Let f be the function defined by $$ f(x) = - ln(x) for 0 < x ≤ 1. $$ R is the region between the graph of f and the x-axis.
    http://learn.flvs.net/webdav/educator_apcalcbc_v10/module08/imgmod08/08_10_01.gif
    b. Determine whether the solid generated by revolving region R about the y-axis has finite volume. If so, find the volume. If not, explain why.
    2. Relevant equations
    $$ y = -ln(x) $$
    $$ x = e^{-y} $$
    3. The attempt at a solution
    $$V = \pi \int_{x=0^+}^{x=1} [e^{-y}]^2 dy $$
    $$V = \pi\int_{∞}^{0} [e^{-2y}] dy $$
    $$\uparrow$$ This is my mistake.
    $$V = -\frac{\pi}{2}$$
    The actual solution is $$V = \pi \int_{0}^{∞}[e^{-2y}] dy = \frac{\pi}{2}$$
    But why are the limits of integration flipped? For part a, (Determine whether region R has a finite area. If so, find the area. If not, explain why.) my limits of integration were [x=0,x=1] $$ \int_{0^+}^{1} -ln(x) dx = 1 $$, so wouldn't I just set $$ e^{-y} $$ equal to 0 and 1 for part b? If not, please explain analytically why I need to flip my limits of integration, I can see from the graph that when x → 0, y → ∞ so please explain the problem analytically. The rotations about the y axes are very tricky for me and ANY advice would help :-) This is a very simple, but confusing concept.
  3. Jan 22, 2014 #2
    Essentially, since ##y=-\ln x## is decreasing on ##(0,1]##, ##dy\sim-dx##. I would advise either setting up the integral entirely in ##x## and then making an obvious (?) substitution, or just set it up entirely in ##y## from the get-go. when you mix stuff up like you did (integrand in one variable, limits in another) in ends badly more often than not in my experience.
  4. Jan 22, 2014 #3
    I just talked to my teacher and she told me that writing the coordinates are helpful when dealing with these type of problems. In this case they will be M(0,∞) and N(1,0) therefore, since we integrate with respect to x from left to right, my limits with respect to x will be $$ \int_{0}^{1} f(x)dx $$ and since we integrate with respect to y from bottom to top, my limits with respect to y will be $$ \int_{0}^{∞} g(y)dy $$
  5. Jan 22, 2014 #4
    Yes. This is what I mean when I say to set things up entirely in one variable or the other. It's just much easier that way.
Have something to add?
Draft saved Draft deleted
