Limits Questions
  • Thread starter mathmann
Evaluate: lim x(squared) - 2x - 8
x-->4 _________________
x (squareroot of x) -8
subbing 4 in as x resulted in an indterminant.
Ive tried using the conjugate but I get stuck when I can not simplify or cancel.
The main problem I'm having is trying to get rid of the squareroot.
Answers and Replies
Dick
26,263
619
What 'conjugate' did you multiply by and what did you get? Show more of your work.
mulitplied both num/den by x(squared) + 2x + 8
which resulted x(to the power of 4) - 4x(squared) - 64 on top
but x (squareroot of x) -8 * x(squared) + 2x + 8
can the denominator be simplified more?
Dick
26,263
619
Try multiplying top and bottom by x*sqrt(x)+8.
if i got you right, the limit you wrote goes like this
lim (x^2-2x-8)/(x*x^1/2 -8), x-->4 right??
if it is like this than you have to multibly both numerator and denominator by
x*x^1/2+8, what do you get? try this first, than you will get further instructions.
after that try to factorize x^2-2x-8, find x1,x2, what do you get, than on the denominator you get x^3-64, try to factorize this too, and the problem is solved!!
i hope this helps
ok i got x(cubed)-2x-64/x(squared)*(x)-64
Dick
26,263
619
Not really right. You should still have a sqrt(x) in the numerator. You don't have to multiply the numerator out. The denominator is ok though, factor it.
x(cubed)-2x(sqrt(x))-64
is the denominator correct?
Dick
26,263
619
If that's supposed to be the numerator, no it's not. It's a binomial times a trinomial - if you do it right you'll get six terms. But I would still encourage you not to do it. Just leave it factored. The denominator IS x^3-64. Have you factored it yet?
x(sqrd)-2x-8 * x((sqrt)x) + 8
_________________________
(x-4)((x(sqrd) + 4x + 16)
Dick
26,263
619
Ok so far. I'd use more parentheses in the numerator. What do you think you should do now? Hint: the (x-4) term is the source of your problems.
I assume theres somewhere that i can reduce but I dont see where.
Is the answer 1/24?
Dick
26,263
619
Is the answer 1/24?
I doubt it. There's a hidden factor of (x-4) in the numerator. Where could it be?
(x-4)(x+2){x(sqrtofx)+8}
(x-4){(xsqrd)+4x+16}
the x-4's cancel and then I can sub x = 4?
I got 1/8
Dick
26,263
619
Good work! But sub again. Carefully this time.
haha whoops 96/48 = 2
Thanks for the help.. much appreciated
yes after you cancel out the (x-4) you can sub the x for 4, but i still think you got the wrong answer. It should be 2.
Related Threads on Limits Questions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
M
  • Last Post
  • Last Post
