Line Integrals 2
  1. Jan 21, 2012 #1
    Evaluate this integral directly
    2. Relevant equations
    [itex]\int cos x sin y dx +sin x cos y dy[/itex] on vertices (0,0), (3,3) and (0,3) for a triangle
    3. The attempt at a solution
    Does this have to evaluated parametrically using [itex]r(t)=(1-t)r_0+tr_1[/itex] for [itex]0 \le t\le 1[/itex]
    or can I just proceed evaluating each line segment in a counter clockwise manner starting with the vertices:
    from (0,0) t (3,3) which gives the line y=x hence dy=dx, substituting in the above
    [itex] \displaystyle I_{ab} = \int_0^3 (cos x sin x + sin x cos x ) dx = \int_0^3 sin 2x dx[/itex]........?
  3. Jan 21, 2012 #2
    How directly is directly? Because using Green's theorem makes this trivial.
  4. Jan 22, 2012 #3
    Yes, i can use green's but i need to verify it directly....
  5. Jan 23, 2012 #4
    Any thoughts on how I calculate this directly?
  6. Jan 23, 2012 #5
    I guess the best way would be to just split it up over each side and evaluate it parametrically.
  7. Jan 23, 2012 #6
    There is no "or" here- the methods you mention are identical. Of course, because the path itself has "corners", you can't have a single polynomial for the entire path- you need a "piecewise" polynomial which is what you have started with- the line from (0,0) to (3,3). Now, the lline from (3, 3) to (0, 3) is given by x= 3- t, y= 0 so that dx= -dt, dy= 0 with t from 0 to 3 Or, equivalently, x= t, y= 0 so that dx= dt, dy= 0 with t from 3 to 0. Note that integrating from 3 to 0 reverses the sign of the integral, giving the same result as the "-dx" when integrating from 0 to 3.
    Now, how would you handle the path from (0,3) to (0,0)?
  8. Jan 23, 2012 #7
    My attempt for (3,3) back to (0,3) is as follows
    THis is a horizontal line at y=3 implies dy=0 therefore the original integral of ∫cos x sin y dx+ sin x cos y dy (and subbing y=3 )reduces to
    [itex]\int_3^0 cos x sin 3 dx[/itex]...? Why isn't this right?
  9. Jan 23, 2012 #8
    I have it thank you.
Similar Threads - Line Integrals Date
Line integral of a curve Dec 27, 2017
Line integral of a vector field Nov 29, 2017
