Homework Help: Line of charge
  1. Jan 18, 2009 #1
    A thin rod of length L with total charge Q. Find an expression for the electric field E at distance x from the end of the rod. Give your answer in component form.
    2. Relevant equations
    Well this isn't a infinite line of charge so this formula should work:
    E = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{Q}{r\sqrt{r^{2} + (\frac{L}{2})^{2}}}[/tex]
    3. The attempt at a solution
    I think I will have to integrate because I cannot cancel components because there is no symmetry in the diagram all electric fields will point in the positive x, negative y direction.
  3. Jan 18, 2009 #2
    Doc Al
    Staff: Mentor
    :confused: Where did this formula come from?
    Yes, you'll have to integrate. Hint: Break the line charge into small elements of length dy.
  4. Jan 18, 2009 #3
    I got that formula from and example in my physics book it is the result after integrating this formula:
    (Ei)x = Eicos[tex]\theta[/tex]i = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{\Delta Q}{r_{i}^{2}}[/tex]cos[tex]\theta[/tex]i
    I think that formula is for a point that bisects the rod only.
  5. Jan 18, 2009 #4
    Doc Al
    Staff: Mentor
    Set up the integral and derive your own formula.
  6. Jan 18, 2009 #5
    Ok here is what I got for the x component:
    r = [tex]\sqrt{y_{i}^{2} + x^{2}}[/tex]
    cos[tex]\theta[/tex]i = [tex]\frac{x}{\sqrt{y_{i}^{2} + x^{2}}}[/tex]
    (Ei)x = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{\Delta Q}{y_{i}^{2} + x^{2}}[/tex][tex]\frac{x}{\sqrt{y_{i}^{2} + x^{2}}}[/tex]
    = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{x\Delta Q}{(y_{i}^{2} + x^{2})^{3/2}}[/tex]
    Ex = [tex]\sum^{N}_{i = 1}[/tex](Ei)x = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\sum^{N}_{i = 1}[/tex][tex]\frac{x\Delta Q}{(y_{i}^{2} + x^{2})^{3/2}}[/tex]
    [tex]\Delta Q[/tex] = [tex]\lambda\Delta y[/tex] = ([tex]\frac{Q}{L}[/tex])[tex]\Delta y[/tex]
    Ex = [tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\sum^{N}_{i = 1}[/tex][tex]\frac{x\Delta y}{(y_{i}^{2} + x^{2})^{3/2}}[/tex]
    = [tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\int_{0}^{L}[/tex][tex]\frac{xdy}{(y^{2} + x^{2})^{3/2}}[/tex]
    = [tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\frac{y}{x\sqrt{y^{2} + x^{2}}}[/tex][tex]\left|_{0}^{L}[/tex]
    = [tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\left[\frac{L}{x\sqrt{L^{2} + x^{2}}} - \frac{0}{x\sqrt{0^{2} + x^{2}}}\right][/tex]
    = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{Q}{x\sqrt{L^{2} + x^{2}}}[/tex]
  7. Jan 18, 2009 #6
    Doc Al
    Staff: Mentor
    Excellent!
  8. Jan 18, 2009 #7
    Ok here is what I got for the y component, I am not sure if this one is right:
    (Ei)y = Eisin[tex]\theta[/tex]i = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{\Delta Q}{r_{i}^{2}}[/tex]sin[tex]\theta[/tex]i
    sin[tex]\theta[/tex]i = [tex]\frac{y_{i}}{\sqrt{y_{i}^{2} + x^{2}}}[/tex]
    (Ei)y = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{\Delta Q}{y_{i}^{2} + x^{2}}[/tex][tex]\frac{y_{i}}{\sqrt{y_{i}^{2} + x^{2}}}[/tex]
    = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{y_{i}\Delta Q}{(y_{i}^{2} + x^{2})^{3/2}}[/tex]
    Ey = [tex]\sum^{N}_{i = 1}[/tex](Ei)y = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\sum^{N}_{i = 1}[/tex][tex]\frac{y_{i}\Delta Q}{(y_{i}^{2} + x^{2})^{3/2}}[/tex]
    Ey = [tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\sum^{N}_{i = 1}[/tex][tex]\frac{y_{i}\Delta y}{(y_{i}^{2} + x^{2})^{3/2}}[/tex]
    = [tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\int_{0}^{L}[/tex][tex]\frac{ydy}{(y^{2} + x^{2})^{3/2}}[/tex]
    = [tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\frac{y}{y\sqrt{y^{2} + x^{2}}}[/tex][tex]\left|_{0}^{L}[/tex]
    = [tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\left[\frac{L}{L\sqrt{L^{2} + x^{2}}} - \frac{0}{0\sqrt{0^{2} + x^{2}}}\right][/tex]
    = [tex]\frac{1}{4\pi\epsilon_{0}}[/tex][tex]\frac{Q}{L\sqrt{L^{2} + x^{2}}}[/tex]
  9. Jan 18, 2009 #8
    Doc Al
    Staff: Mentor
    Good.
    Cancel those y's. (And be careful with the sign of the integral.)
  10. Jan 18, 2009 #9
    Ok, I made the changes:
    = -[tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\frac{1}{\sqrt{y^{2} + x^{2}}}[/tex][tex]\left|_{0}^{L}[/tex]
    = -[tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\left[\frac{1}{\sqrt{L^{2} + x^{2}}} - \frac{1}{\sqrt{0^{2} + x^{2}}}\right][/tex]
    = -[tex]\frac{\frac{Q}{L}}{4\pi\epsilon_{0}}[/tex][tex]\left[\frac{1}{\sqrt{L^{2} + x^{2}}} - \frac{1}{\sqrt{x^{2}}}\right][/tex]
  11. Jan 18, 2009 #10
    Doc Al
    Staff: Mentor
    That looks good. Move that outside minus sign inside. (Switch the order of subtraction in the brackets.)
