Void123
- 141
Consider a negative charge placed initially at a distance [tex]r_{0}[/tex] from an infinite line with positive charge density [tex]\lambda[/tex]. The charge is given an initial velocity of magnitude [tex]v_{0}[/tex] parallel to the line of charge.
Find an expression for the trajectory of the particle in which time has been eliminated. This expression relates the distance traveled by the charge parallel to the line and the distance traveled perpendicular to the line.
[tex]m\stackrel{\rightarrow}{\ddot{r}}(x, y) = q\stackrel{\rightarrow}{E}[/tex]
Using the Gaussian integral, I calculated the electric field
[tex]E\propto\frac{\lambda}{r}[/tex]
I found that [tex]x=v_{0}t[/tex]
Since the charge has an initial velocity in the horizontal direction and a force acting on it in the vertical direction due to the electric field, I know that it will follow a projectile motion as it travels parallel to the line.
How would I eliminate time from my equations? And would my final expression be some r(x, y) of the parabolic type?
Thanks.
