Linear Algebra Ax=b
Construct a 3x3 matrix A and vectors b and c in R^3 so that Ax=b has a solution but Ax=c
So I don't know where to start. I am not sure if the problem is asking me to create a matrix with real numbers or variables. What I do know is that Ax=b has a solution if each row has a pivot , except the last column. So How would I use this to answer the question?
Answers and Replies
andrewkirk
Insights Author
1,495
You left off a "doesn't" at the end of the question.
Taking that as read, the matrix has to be singular, otherwise we can just left-multiply both sides by ##A^{-1}## to find solutions for both equations.
What is the simplest, most monotonous, singular, 3 x 3 matrix you can think of?
If you call that matrix A, what is the only vector b for which A x = b will have a solution x?
I suspect that may not be the matrix they are looking for, but that's the simplest and most natural answer to the question as posed.
Ok thank you for your help
Related Threads on Linear Algebra Ax=b
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
