Linear Algebra - Finding Rank
Suppose that AB = 0, where A is a 3 x 7 full rank matrix and B is 7 x 53. What is the highest possible rank of matrix B.
Since each column of B is in the null space of A, the rank of B is at most 4.
I don't understand why it is 4.
What operation do I need to perform here to understand this? I am not a student, I am just trying to remember Linear Algebra.
Answers and Replies
Instead of these unwieldy matrices, let us consider the linear transformations they represent. For the sake of simplicity, let's denote the dimension of a vector space by an index. Then we have ##A\, : \,V_7 \longrightarrow V_3## and ##B\, : \, V_{53} \longrightarrow V_7\,.## So ##B## sends at least ##53-7=46## dimensions to zero anyway. Thus its rank must be between ##7## and ##0##. ##A## on the other hand sends exactly ##4## dimensions to zero, as it is of full rank. But both applied in a row: $$V_{53} \stackrel{B}{\longrightarrow} V_7 \stackrel{A}{\longrightarrow} V_3$$ sends all ##53## dimensions to zero. Now how many can ##B## leave from those ##7##, which will be left for ##A## to be sent to zero?
Likes TickleTackleTock
So, if Matrix A were instead a 8 x 3 matrix, then B would have a rank of five? What I am seeing is that it is the subtraction of columns from rows in order to find the rank of B that maps A to 0?
In this case you couldn't multiply the matrices in the first place. This means for the transformations, that we need to explain, what happens between the 8-dimensional image of ##B## and the 7-dimensional space, on which ##A## is defined.
You can translate it into row and column actions, too. But as we don't have a certain example, we can assume that the matrices are already in a form which is nice:
A=\begin{bmatrix}I_3 & | & 0_4 \end{bmatrix}\, , \,B=\begin{bmatrix} B_7^{\,'}&| &0_{46}\end{bmatrix}
with the ##(3\times 3)## identity matrix ##I_3## and any ##(7 \times 7)## matrix ##B_7^{\,'}##. This wouldn't change the result but is easier to handle. Now calculate ##AB =0## and see what does this mean for ##B_7^{\,'}## and its maximal rank.
Here are a couple of formulas which also might help occasionally: https://en.wikipedia.org/wiki/Rank_(linear_algebra)#Properties
In your example above I basically used https://en.wikipedia.org/wiki/Rank–nullity_theorem
Sorry about that. I mean a a 2 x 7 matrix. That way the numbers would change a bit.
So, in this case(Your new example), the Rank(A) = 3, Rank(B) = unknown and the Rank(AB) = 0. Which is exactly the same as the previous example. I appreciate your help but I think that I am going to read through an introductory book again. It is apparent that I don't remember enough. Thank you!
A couple other approaches:
1.) Work through the Sylvester rank Inequality proof. Then apply it here.
2.) Less general, using gramm schmidt in reals, you can reason that all columns both B are orthogonal to the rows of A, and hence this implies what?
Suggested for: Linear Algebra - Finding Rank
