Homework Help: Linear algebra help
  1. Nov 5, 2009 #1
    Explain why, if A is an n by n matrix,
    and [1, . . . , 1] is a 1 by n matrix, then [1, . . . , 1]A will be a 1 by n matrix whose ith entry equals the sum of the entries in the ith column of A. Then use this idea to do the following problem.
    1)Let P be an nxn probability matrix and let Z be an nx1 matrix. Prove that the sum of the entries in PZ is the same as that of the entries in Z.
    2)Prove that the product of two probability matrices is a probability matrix.
    3)Let P be an nxn probability matrix and let X=[1,1,...,1]t be the nx1 matrix, all whose entries are 1. What is P^tX?(Try some examples if you are not sure.) How does it follow that det(Pt - I)=0 ?How does it follow that det(P-I)=0 how does this relate to proving theorem 3?
    4)Prove that for any 2x2 probability matrix P the vector Y=[1,-1]t is an eigenvector. Then prove theorem 3 in the 2x2 case.
    2. Relevant equations
    {Theorem 3; let P be a probability matrix with no entries equal to 0. Then there is a unique probability vector X such that PX=X. If D is any probability vector, then (lim->∞ PnD=X)}
    3. The attempt at a solution
    I don't know where to go with this all I know is an arbitrary 2-by-2 probability matrix will have the form [[a,b],[1-a,1-b]]
    Note that Theorem 3 applies to most but not all probability matrices (so the assumptions about a and b have to be modified when proving Theorem 3). Note also that I need to prove not just that an equilibrium vector exists, but that it is unique. When proving the final claim in Theorem 3 (Pn V0 → X as n → ∞),
    I believe it suffices to assume that the sum of the entries in V0 equals 1; the condition that those entries be non-negative shouldn’t get used in the proof.
    This is all so confusing to me, I think I can handle this if I was given a direction to go. Could someone give me a hint as to how to handle this problem.
  3. Nov 5, 2009 #2
    lanedance
    ok, so what is your definition of a probabilty matrix, something about rows and/or columns with non-negative entries summing to one?
    1) should follow from row/column properties of the probabilty matrix, starting in subscript notation (nx1 vectors are represented by only one index)
    [tex] (PZ)_{i} = \sum_j P_{ij} Z_{j} [/tex]
Loading...
