Linear algebra proof check
  1. Feb 15, 2012 #1
    Prove that if subspace W contain a set of vectors S, then W contain the span(S)
    2. Relevant equations
    3. The attempt at a solution
    Let's take a vector [itex]x\in span(S)[/itex], i have to show [itex]x\in W [/itex] also. (*)
    So since [itex]x\in span(S)[/itex] there are scalrs [itex]c_1...c_n[/itex] so that [itex]x = c_1s_1 ...c_ns_n[/itex] where [itex]s_1...s_n[/itex] are elements of S.
    Let's take [itex]s_1 = \frac{x}{c_1} - \frac{c_2}{c_1} - ...-\frac{c_n}{c_1}[/itex] which is of course an elemtent of S.
    Since [itex] S \subseteq W[/itex] s is an element of W also.
    Since W is a vector space [itex] c_1s_1 + c_2s_2 + ... + c_ns_n = x[/itex] is still an element of W, so x is an element of W
    I'd like a check, thanks :)
    EDIT: I'm adding a part after the (*)
    If x is the zero vector, then any space contains the zero vector and we are done. If x is not the zero vector then there are scalars [itex]c_1...c_n[/itex] where at least one is not zero, let that scalar be c_1, so that [itex]x = c_1s_1 ...c_ns_n[/itex] where [itex]s_1...s_n[/itex] . . .
  3. Feb 15, 2012 #2
    If W contains S, since W is a subspace, any linear combinations of the vectors in S will also in W, hence W contains span(S).
  4. Feb 15, 2012 #3
    Thank you, and your proof is even much simpler and short than mine.
    But i still would like to know if mine is correct.
  5. Feb 15, 2012 #4
    I'd just use what Some Pig used too, if you're a subspace you contain the span of any combination of your vectors.
    Regarding your proof, your last two lines are all you really need as such your proof is correct.
  6. Feb 16, 2012 #5
    Thanks a lot
  7. Feb 16, 2012 #6
    No problem buddy!
  8. Feb 16, 2012 #7
    This is wrong (and useless) since s1 is already given, not what you specify, and x is a vector and c2/c1,etc. are scalars, the subtraction is undefined
  9. Feb 17, 2012 #8
    Yes i made a huge mistake in writing that, what i meant to say was [itex]s_1 = \frac{x}{c_1} - \frac{c_2}{c_1}s_2 - ...-\frac{c_n}{c_1}s_n[/itex]
