Linear algebra proof
  • Thread starter Mdhiggenz
Let x,y,and z be vectors in a vector space V. Prove that if x+y=x+z
then y=z
I know it cant be as simple as just subtracting vector x from both sides.
What i'm thinking is out goal is to get y=z which means that there much be a zero vector
in the relationship x+y=x+z.
My guess is that x is the zero vector in this case. I'm not that good with proofs yet, but I have been reading "How to prove it" so i split it up into givens and goals.
given is x,y,and z be vectors in a vector space V and x+y=x+z
goal being y=z.
am I allowed to grab one of the axioms as a staring point for the proof?
Answers and Replies
Dick
26,258
619
then y=z
goal being y=z.
Yes. Exactly. Grab the axiom that says that every vector x has an additive inverse.
I think I got it. Would this be a correct proof.
A1. x+y=y+x
A2. (x+y)+z=x+(y+z)
A3. x+0=x
A4. x+(-x)=0
These are the axioms I used.
Here is the proof: Assume A1. x+y=y+x
using A3 we get the following substitution x-x+y=y+x-x
y=y+(x-x). Using A2 and A1 y=(x+y)-x. Given that x+y=x+z, we can substitute
y=(x+z)-x using A2 y=z+(x-x) now using A3 we get y=z+0
thus y=z
done.
It seems you haven't seen an "If, then" type of question before. Basically, you are given the "if" and you work towards the "then" part. In this case, start with the given: ##x + y = x + z## line and use axiom(s) to get to ##y = z##.
Yea karnage, i'm still a bit rusty on those but if I start with that couldnt I just use one axiom to get to the goal.
E.g x+y=x+z
(x-x)+y=(x-x)+z A3
then y=z
Yup, that is correct. Although you would first add (-x) then use associativity to combine the x and (-x) to make 0, which is two steps.
Related Threads on Linear algebra proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
