Linear Algebra question
  • Thread starter daniel_i_l
daniel_i_l
prove or disprove:
1) (z is complex and bar(c) is the conjugate of c)
If c and bar(c) are solutions to z^2 + az + b = 0 and c isn't real then a and b are real.
2) If S and T are subsets of the space V and intersection of Sp(S) and Sp(T) is {0} then the intersection of S and T is an empty set. (Sp is the span)
1) I wrote z as x+yi and got:
x^2 + 2xyi - y^2 + ax + ayi +b = x^2 -2xyi - y^2 +ax - ayi +b
and so:
4xyi + 2ayi = 0 => 2x + a = 0 => a=-2x which is real. and by putting that into the equation I get that b is also real. So the answer is True.
2) If S = T = {0} then the intersection of both Sp(S) and Sp(T) and S and T is {0}. So the answer is False.
Is that right? Am I missing anything here? especially the last one seemed too easy.
Thanks.
Answers and Replies
AKG
2,565
Both your answers are right. Note in your work for the first one, you have "4xyi + 2ayi = 0 => 2x + a = 0." Be aware that this is only valid because y is non-zero, which is because c isn't real. Another way to do 1) is this:
If c and [itex]\bar{c}[/itex] are the solutions to z2 + az + b = 0, then [itex](z-c)(z-\bar{c}) = z^2 + az + b[/itex]. Multiplying the left side out gives [itex]z^2 - (c+\bar{c})z + c\bar{c}[/itex], which is just z2 - 2Re(c)z + |c|2, and so a = - 2Re(c), and b = |c|2, both of which are clearly real quantities.
Related Threads on Linear Algebra question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
