Linear algebra: vector spaces
  • Thread starter phys2
phys2
Hi, I am really having trouble with questions regarding proving whether a given set is a vector space or not.
So one of the questions is [ x ε R2|x12=x23 ]
So I have to prove whether the following set is a vector space
Having a peek at the textbook, it tells me that there are ten axioms that satisfy whether a set belongs to a vector space.
What I did was go x12 - x23 = 0
u+ v = v + u -For this one, I did the following: I let x1 and x2 have a value each and named it a vector u, then I let x1 and x2 have some other values and named it a vector v.
So x1 = 1 and x2 = 2 and u = 12 - 23
And x1 = 4 and x2 = 5 and v = 42 - 53
u + v = v + u should work out and I used the same method for the rest of the axioms....I need to know two things
(a) Is the method I am doing correct? If not, could you point me in the right direction?
(b) How do I go about checking the first axiom for the above set u + v lies in the set. If I do the same old substitution, all i get is a number, whatever it is!
Thanks
Answers and Replies
jbunniii
Insights Author
257
Many of the axioms will be satisfied automatically because this set (let's give it a name: [itex]S[/itex]) is a subset of a vector space.
For example, if [itex]u[/itex] and [itex]v[/itex] are in [itex]S[/itex], then they are also in [itex]\mathbb{R}^2[/itex], and since [itex]\mathbb{R}^2[/itex] is a vector space, addition is commutative. Therefore [itex]u + v = v + u[/itex].
The main things to check are whether [itex]S[/itex] is closed under vector addition and scalar multiplication. The fact that [itex]S[/itex] is defined in terms of squares and cubes of the vector coordinates is a pretty good indication that [itex]S[/itex] is not a vector space. This is because squaring and cubing are both nonlinear operations, and vector spaces are all about linearity.
Try picking a specific element of [itex]S[/itex], for example [itex]v = (1,1)[/itex]. Is there a scalar multiple of [itex]v[/itex] that is not in [itex]S[/itex]? Is [itex]v + v[/itex] in [itex]S[/itex]?
phys2
Yea, that is really the part (b) of the problem that I faced. I don't think I can take v = (1,1) though since both numbers have to be different x12 - x23 Anyway, even if I take two different numbers, what I get is another number. How do I know whether that number is part of set S or not?
For instance, if I take v = (1,2), I will get 1-8 = -7. How do I know -7 is in S?
I did check all the rules using the method that you have mentioned, taking numbers and figuring out whether the axioms are satisfied...but I wasn't sure whether that was a reasonable method...but since you argue in the same way, I guess it is.
Thanks for your input.
jbunniii
Insights Author
257
I think you're misunderstanding the condition [itex]x_1^2 = x_2^3[/itex]. The vector [itex]v[/itex] is in [itex]S[/itex] if and only if its components satisfy [itex]x_1^2 = x_2^3[/itex]. In your example, [itex]x_1 = 1[/itex] and [itex]x_2 = 2[/itex], so [itex]x_1^2 = 1[/itex] and [itex]x_2^3 = 8[/itex]. Since [itex]1 \neq 8[/itex], this means that [itex]v[/itex] is not in [itex]S[/itex].
Now consider my example again: [itex]v = (1,1)[/itex]. In this case, [itex]x_1 = 1[/itex] and [itex]x_2 = 1[/itex], so [itex]x_1^2 = 1[/itex] and [itex]x_2^3 = 1[/itex]. Therefore [itex]x_1^2 = x_2^3[/itex], so [itex]v \in S[/itex].
So now that we have established that [itex]v = (1,1)[/itex] is in [itex]S[/itex], you can easily use this to show that [itex]S[/itex] is not closed under addition and scalar multiplication, so [itex]S[/itex] is not a vector space. It doesn't matter that it satisfies the other axioms. If it isn't closed under addition and scalar multiplication, it cannot be a vector space.
To show that [itex]S[/itex] is not closed under addition and scalar multiplication, consider the vector [itex]v + v = (2,2)[/itex]. If [itex]S[/itex] is a vector space, then [itex](2,2)[/itex] must be in [itex]S[/itex]. Is it?
phys2
To show that S is not closed under addition and scalar multiplication, consider the vector v+v=(2,2). If S is a vector space, then (2,2) must be in S. Is it?
(2,2) is not in S because 22 = 4 and 23 = 8 and 4≠8.
I am still confused about showing that S is not closed under addition and scalar multiplication.
With addition, I know that the axiom is u + v = v + u
So if I take v = (2,2), u = (1,2), do I just do it the normal vector addition way; adding the x1s together and the x2s together?
So v+ u = [ (22 + 12) , ( 23 + 23) ] = (5, 16)
u + v= [ (12 + 22) , (23 + 23) ] = (5,16)
Seems like it is closed under vector addition or I am probably doing something wrong?
jbunniii
Insights Author
257
Addition is defined in the usual way: [itex](2,2) + (1,2) = (2+1, 2+2) = (3,4)[/itex]. The [itex]x_1^2 = x_2^3[/itex] relation is just a constraint which tells you which vectors are in [itex]S[/itex]. It has nothing to do with how you add vectors or multiply by scalars.
phys2
The x21=x32 relation is just a constraint which tells you which vectors are in S. It has nothing to do with how you add vectors or multiply by scalars.
Oh, I think I get it. What we have done so far is find vectors that belong or do not belong to S. Example: v = (1,2) does not belong to S and v= (1,1) belongs to S.
But v = (1,1), even if it belongs to S, that does not necessarily make it a vector space, I need to do do the addition and scalar multiplication to figure it out. Is my understanding correct so far?
v = (2,2) is not in S so S is not a vector space? What I know about vector spaces is that, take R2 for an example. R2 is a vector space because you can take any linear combinations of vectors (x1, x2) and they all lie in R2.
jbunniii
Insights Author
257
Yes, that's right.
Right. Now, we already established that v = (1,1) is in S. Now let's take a linear combination of elements of S: (1,1) + (1,1) = (2,2) is a linear combination, namely 1v + 1v. If S is a vector space, then S must contain all linear combinations of its elements. Therefore if (2,2) is not in S, then S cannot be a vector space.
phys2
Yes, I finally get it now. Using the same method, I should be able to get through all the problems.
Thanks a lot for your help!
Suggested for: Linear algebra: vector spaces
  • Last Post
  • Last Post
  • Last Post
  • Last Post
