Linear Algebra - Vectors
  • Thread starter Whiz
A plane flies at 400 km/h [south 30 degrees east]. The wind is blowing from the east at 100 km/h. Find the resulting speed of the plane.
Not sure
I've drawn a diagram similar to this:
|30\
| \ 400 km/h
|_____\
100km/h
I thought this was just a simple question of finding the left side of the triangle, but I don't seem to get the answer. Any hints is greatly appreciated.
Thank you in advance.
Answers and Replies
6,760
You have drawn a 30-60-90 right triangle. If the hypotenuse is 400 km/hr, the base would be 200 km/hr, not 100 km/hr.
Decompose the plane's velocity into a south component and and east component.
Hmm so would this work?
use 30 degrees and 400 km/h to find the speed going straight south
cos (30) * (south_speed/400)
south_speed = cos(30) * 400 = 346
Then use speed going straight south and incorporate the 100km/h wind blowing west, use Pythagorean theorem and find the resultant speed(hypotenuse)?
346^2 + 100^2 = 130000^2
= 360.5
Does that seem right?
LCKurtz
Insights Author
770
Set up a vector for the plane velocity: P = < ?, ?>
Write a vector for the wind velocity: W = <?, ?>
The resultant velocity is V = P + W and its length is the groundspeed.
Can you please show me how? I was only only taught how to do it when the points were given.
LCKurtz
Insights Author
770
Think of the plane as at the origin with the x direction East and y direction North. The direction described as "South 30 degrees East" is the polar coordinate angle -60 degrees. So the plane velocity is given to you in polar coordinates, r = 400 and [itex]\theta = -\pi/3[/itex]. Use the polar coordinate equations to get P = <x, y> for the airplane. And you should easily be able to write the wind vector since you are given its length 100 and direction "from the East".
By the way, I didn't say your answer was incorrect. I'm just trying to show you how you should set up such problems.
6,760
= 360.5
Yes, this is pretty close. I get a slightly larger figure since I didn't round off what you're calling south_speed, which I get as 346.41 km/hr (approx.).
Related Threads on Linear Algebra - Vectors
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
21K
  • Last Post
  • Last Post
