Linear Algebra
  • Thread starter Ted123
[PLAIN]http://img219.imageshack.us/img219/2950/linl.jpg [Broken]
Is this how I do part (iii)?
From (ii) I get:
[itex]M^{\mathcal C}_{\mathcal C} (\phi) = \begin{bmatrix} 1 & 3 & 2 \\ 1 & -3 & 0 \\ 0 & 0 & 2 \end{bmatrix}[/itex]
3(iii)
[itex]M^{\mathcal C}_{\mathcal C} (\phi) {\bf v} = {\bf w}[/itex] where [itex]{\bf w}[/itex] is the coordinate vector of [itex]\phi (v)[/itex] with respect to [itex]\mathcal C[/itex] and [itex]{\bf v}[/itex] is the coordinate vector of [itex]v\in V[/itex] .
[itex]{\bf v} = \begin{bmatrix} 1 \\ -3 \\ \pi \end{bmatrix}[/itex]
So [itex]{\bf w} = \begin{bmatrix} 1 & 3 & 2 \\ 1 & -3 & 0 \\ 0 & 0 & 2 \end{bmatrix} \begin{bmatrix} 1 \\ -3 \\ \pi \end{bmatrix} = \begin{bmatrix} 2\pi -8 \\ 10 \\ 2\pi \end{bmatrix}[/itex]
Answers and Replies
vela
Staff Emeritus
Education Advisor
15,097
1,675
Yes, that's the correct method.
Is the matrix M^C_C(phi) supposed to be the matrix of phi in the ordered basis C? If so, your matrix is incorrect; 1+x, 1-x, and 1+x^2 are eigenvectors of phi, with eigenvalues 1, 3, and 2, respectively. The matrix you are looking for is a diagonal matrix.
Your approach for (iii) is correct; simply multiply the matrix of phi in the basis C by the coordinate matrix v; that will give you the coordinate matrix of phi(v).
vela
Staff Emeritus
Education Advisor
15,097
1,675
I concur. I get a different matrix for part (ii).
Well this is my approach to the whole question:
Part (i)
[itex]\phi (1) = 2-x = 2(1) -1(x) + 0(x^2)[/itex]
[itex]\phi (x) = -1 + 2x = -1(1) + 2(x) + 0(x^2)[/itex]
[itex]\phi (x^2) = x + 2x^2 = 0(1) + 1(x) + 2(x^2)[/itex]
[itex]M^{\mathcal B}_{\mathcal B}(\phi) = \begin{bmatrix} 2 & -1 & 0 \\ -1 & 2 & 1 \\ 0 & 0 & 2 \\ \end{bmatrix}[/itex]
Part (ii)
Since [itex]{\mathcal C}[/itex] has size 3 and [itex]\text{dim}(\mathbb{R}_2[x])=3[/itex] it is enough to show that [itex]\mathcal C}[/itex] is either linearly independent or spans [itex]V[/itex] . For completeness let's do both.
[itex]{\mathcal C}[/itex] is linearly independent if
[itex]\alpha (1+x) + \beta (1-x) + \gamma (1+x^2) = 0 \Rightarrow \alpha = \beta = \gamma = 0[/itex]
[itex]\alpha + \alpha x +\beta - \beta x + \gamma + \gamma x^2 = 0[/itex]
[itex]\alpha + \beta + \gamma + (\alpha - \beta)x + \gamma x^2 = 0[/itex]
Equate coefficients.
[itex]\alpha + \beta + \gamma = 0[/itex] (1)
[itex]\alpha - \beta = 0 \Rightarrow \alpha = \beta[/itex] (2)
[itex]\gamma = 0[/itex] (3)
Subbing (2) and (3) in (1) gives [itex]2\alpha = 0 \Rightarrow \alpha = 0 \Rightarrow \beta = 0[/itex] from (2).
Hence [itex]\alpha = \beta = \gamma = 0[/itex] and [itex]\mathcal C[/itex] is linearly independent.
[itex]\mathcal C[/itex] spans [itex]V[/itex] if
[itex]a_1 (1+x) + a_2 (1-x) + a_3 (1+x^2) = b_1 + b_2 x + b_3 x^2[/itex]
has at least one solution for every set of coefficients [itex]b_1,b_2,b_3[/itex]
[itex]a_1 + a_2 + a_3 + (a_1 - a_2)x + a_3x^2 = b_1 + b_2 x + b_3 x^2[/itex]
Equating coefficients yields the following system of equations (*):
[itex]a_1 + a_2 + a_3 = b_1[/itex]
[itex]a_1 - a_2 = b_2[/itex]
[itex]a_3 = b_3[/itex]
Transforming the augmented matrix
[itex]\begin{bmatrix} 1 & 1 & 1 & 1 & 0 & 0 \\ 1 & -1 & 0 & 0 & 1 & 0 \\ 0 & 0 & 1 & 0 & 0 & 1 \\ \end{bmatrix}[/itex]
into row echelon form we get
[itex]\begin{bmatrix} 1 & 0 & 0 & \frac{1}{2} & \frac{1}{2} & -\frac{1}{2} \\ 0 & 1 & 0 & \frac{1}{2} & -\frac{1}{2} & -\frac{1}{2} \\ 0 & 0 & 1 & 0 & 0 & 1 \\ \end{bmatrix}[/itex]
which corresponds to the following system of equations:
[itex]a_1 = \frac{1}{2}b_1 + \frac{1}{2}b_2 -\frac{1}{2}b_3[/itex]
[itex]a_2 = \frac{1}{2}b_1 -\frac{1}{2}b_2 -\frac{1}{2}b_3[/itex]
This system {and therefore the system (*)} are consistent for all RHS values, therefore [itex]\mathcal C[/itex] spans [itex]V[/itex] .
We can therefore conclude that [itex]\mathcal C[/itex] is certainly a basis for [itex]V[/itex] .
[itex]\phi (1+x) = (2-1) + (-1+2)x = 1 + x = 1(1) + 1(x) + 0(x^2)[/itex]
[itex]\phi (1-x) = (2+1) + (-1-2)x = 3-3x = 3(1) - 3(x) + 0(x^2)[/itex]
[itex]\phi (1+x^2) = 2 + (-1+1)x + 2x^2 = 2+2x^2 = 2(1) + 0(x) + 2(x^2)[/itex]
Part (iii)
You don't need to do all of that work. For (i) (and (ii)) simply find the coordinate matrices of phi(1), phi(x) and phi(x^2) in the ordered basis B (or phi(1+x), phi(1-x), phi(1+x^2) in the ordered basis C). These coordinate matrices are, in order, the columns of the matrix you seek.
Now, for part (ii), to show that those three functions are a basis, it suffices to show that they are linearly independent. This is not difficult to do, and your way works fine.
If M^B_B(phi) is indeed meant to represent the matrix of phi in the ordered basis B, then I think your only mistake is that you are misunderstanding what this matrix is.
The matrix for (1) is definitely correct (I was told it was by the lecturer) so the method I am using is correct (and is what we were taught).
I know I only need to show EITHER linear independence OR span for part (ii) but for COMPLETENESS (and to make sure I could do both) I did BOTH!
[PLAIN]http://img832.imageshack.us/img832/1083/matrixtp.jpg [Broken]
I've just noticed that I've wrote the images of the vectors in C as a linear combination of the vectors in B rather than C for part (ii)...
Sorry, just realized you already wrote that; I was confusing the numbers on your question. Under part (i) I think you wrote something different on the solution from what was written in the problem; it seems as though part (i) of the problem is under part (ii) of your solution. Yes, you are exactly right.
Just read your last post; that definition is what I was thinking of.
I didn't mean to reiterate that point about only needing to show independence; I see you already wrote that.
Hope I could help.
The coordinate matrices for phi(1), phi(x), phi(x^2) in the ordered basis B be should be obtained as follows.
phi(1) = 2 - x = 2(1) - 1(x) + 0(x^2);
phi(x) = -1 + 2x = -1(1) + 2(x) + 0(x^2);
phi(x^2) = x + 2x^2 = 0(1) + 1(x) + 2(x^2).
(Wish I knew how to use Tex, for your sake!) From the above equations, you can read of the coordinates; those are the columns of your matrix. In fact, your matrix should be the transpose of the coefficient matrix of the above system of equations. Deal similarly with the ordered basis C (it's a bit easier; as I said before, the elements of C are each eigenvectors of phi).
I know - that's how I got the matrix for part (i)!
Sorry I just noticed I posted my working to a completely different question before...
vela
Staff Emeritus
Education Advisor
15,097
1,675
Yeah, that's your mistake.
Sorry about that confusion, I just realized that.
Hope I could help.
Sorry everyone!
Just to clarify I posted my working to a completely different question before and mixed up the numbering of the question parts in my working!
It seems my mistake for part (ii) is writing the images as a linear combination of vectors in B rather than C.
So is this correct:
[itex]M^{\mathcal C}_{\mathcal C} (\phi) = \begin{bmatrix} 1 & 0 & 0 \\ 0 & 3 & 0 \\ 0 & 0 & 2 \end{bmatrix}[/itex]
(And obviously then I've got to correct part (iii) )
vela
Staff Emeritus
Education Advisor
15,097
1,675
Yeah, that's the right matrix.
Related Threads on Linear Algebra
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
