Linear Algebra
  • Thread starter gunnar
gunnar
40
There are two vectors (1,0,-1) and (0,1,1)
I need to find all the unit vectors x in R3 that make an angle of pi/3 with each of the vectors above.
Can someone please help with this problem?
Answers and Replies
vincentchan
609
hint:
use dot product to find the angle between vectors
Hurkyl
Staff Emeritus
You should be able to use the three constraints on your solution vector (unit vector, specified angle with a vector, specified angle with another vector) to write down three equations in the components of your solution vector. Then, solve.
gunnar
40
O.K I figured out that the angle between the given vectors is 60 degrees or pi/3
The angle between the unit vectors and each of the given vectors is supposed to be pi/3 also. So I used the dot product to calculate
c=sqrt(2) since the unitvector has length 1 and both the given vectors have the length sqrt(2)
Don't seem to be able to get the right answear.
The correct answear is (1/sqrt(2), 1/sqrt(2), 0) only one vector.
How to reach that conclusion I have no idea
da_willem
599
Lets call the components of the vector you seek (a,b,c). Now there are three restriction on these three numbers. So when you write down the tree restrictions Hurkyl gave in terms of a,b and c you have three equations with three unknowns which you can solve. Can you translate the restrictions from words to algebra?
Suggested for: Linear Algebra
  • Last Post
  • Last Post
