Linear and angular momentum
  • Thread starter dyn
dyn
700
49
Hi,
I,ve been looking through some notes on Lagrangian mechanics but they have got me confused so i'll start from the beginning.
If a point mass is moving in the x-y plane with constant velocity v at a y-coordinate r then it has linear momentum mv which is a constant but it has an angular momentum about the origin of mrv at x=0 ? If the point mass continues in the positive x direction towards ∞ then it its angular momentum must tend to zero ? What happens to conservation of angular momentum ?
Answers and Replies
38
Are your sure that the angular momentum would tend toward zero? What happens to the angular velocity as the mass continues moving in the positive direction?
dyn
700
49
I was using angular momentum=mrvsinθ and as x→0 then sinθ→0
dyn
700
49
I meant as x→∞ then θ→0 and sinθ→0
dyn
700
49
I've figured that now. The angle gets smaller but the modulus of the position vector gets bigger so the angular momentum stays the same.
So all linear motion that is not radial has an angular momentum about the origin ?
For a point mass is there such a thing as total momentum combining linear momentum and angular momentum ?
Linear and angular momentum can't be summed up together as they have different units, so their mere sum won't make sense
Likes 1 person
Related Threads on Linear and angular momentum
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
20K
  • Last Post
