1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Linear Approximation
  1. May 31, 2006 #1
    So I have this as the last thing I don't understand before tommorrow's test.. I have tried reading in the book and online, but it's just not clicking for me!
    There are so many numbers, and it they seem to just plug them in from nowhere.
    Like some example problems would be like sqrt(25.1) and 2.001^5.
    Supposedly I use the equation L(x) = f(a) - f'(a)(x-a)? But I have no idea which numbers I plug in where.. is this easier than I'm making it to be?
  3. May 31, 2006 #2
    matt grime
    It would be easier if you read it as:
    L(a+e)= f(a) +f'(a)e
    that is the value at 'a' plus a little bit (e) is approximately linearly related to the value at 'a' using the derivative at 'a'.
    so the square root of 25.1 is approximately the square root at 25 plus the derivative at 25 (of the square root function) times 0.1
    All you're doing is using the first two terms of the Taylor/MacLaurin series to estimate the whole sum. For small 'e' this is approximately good enough.
  4. May 31, 2006 #3
    HallsofIvy
    Staff Emeritus
    I think it might help you to read the problem correctly! You say "Like some example problems would be like sqrt(25.1) and 2.001^5."
    I hope you understand that "sqrt(25.1)" and "2.001^5" are numbers, not problems! State (at least to yourself) clearly what you are supposed to do with those numbers!
    I suspect that the problem really is something like this:
    "Use the tangent line approximation to give a simple approximation to sqrt(25.1)" or "approximate sqrt(25.1) without using a calculator".
    Then you should think to yourself, "Alright, I know that sqrt(25)= 5 so I don't need a calculator for that! I also know that the tangent line to f(x) at x= a is given y(x)= f(a)+ f'(a)(x-a). Since I am asked to find sqrt(25.1), I had better take x= 25.1! Since I need to be able to find f(a)= sqrt(a) (with a as close to the given point as possible) , I had better take a= 25.
    Similarly with "Use the tangent line approximation to give a simple approximation to 2.0015. Since you are specifically asked to find f(2.001) (approximately), you should take x= 2.001. Since you need to be able to find f(a)= a5 easily, and have a close to 2.001, you should take a= 2.
Have something to add?
