Linear independence
  1. Jan 18, 2010 #1
    If the set {v1,v2,v3} of vectors in R^(m) is linearly dependent, then argue that the set {v1,v2,v3,v4} is also linearly dependent for every choice of v4 in R^(m).
    2. Relevant equations
    Definitions would be more relevant so...
    Linearly Independent: If the only solution is the trivial solution
    Linearly Dependent: If there are more solutions than he trivial solution.
    3. The attempt at a solution
    I started out by writing out three vectors that are a dependent set, and I noticed that no matter what I added for v4 there would still be that non trivial solution, therefore making it remain dependent.
    Is that sound reasoning?
  3. Jan 18, 2010 #2
    Hi EV33! :smile:
    (try using the X2 and X2 tags just above the Reply box :wink:)
    If I'm guessing correctly what you mean, then yes that's sound.
    But you should write it properly, starting "if v1 v2 and v3 are dependent, then there exist …" :wink:
  4. Jan 18, 2010 #3
    Thank you very much
