Linear momentum and collision
  • Thread starter ch010308
A 5.00-g bullet moving with an initial speed of 400 m/s is fired into and passes through a 1.00-kg block, as in Figure P9.67. The block, initially at rest on a frictionless, horizontal surface, is connected to a spring of force constant 900 N/m. If the block moves 5.00 cm to the right after impact, find
(a) the speed at which the bullet emerges from the block and
(b) the mechanical energy converted into internal energy in the collision.
conservation of momentum
KE=1/2 mv2
I solved part a, getting an answer of 100m/s for the speed at which the bullet emerges from the block. But I'm stuck at part b.
I interpreted the question as: finding the mechanical energy tat was converted = change in mechanical energy = change in kinetic energy of the bullet = 1/2 m(vf -vi) = (1/2)(5/1000)(100-400)2 = 225J
The correct answer should be 374J.
Pls help, thanks! :)
Answers and Replies
rl.bhat
4,433
What is the role played by the spring in this problem?
lanedance
3,304
hi
havenl't been through it all, but one thing that stands out is your last calc of cahnge in KE
should be
1/2 m(vf^2 -vi^2)
NOT
1/2 m(vf -vi)^@2as you've done in your calc
should be
1/2 m(vf^2 -vi^2)
NOT
oh shoot! I cant believe I made tt mistake again n again. :tongue2: Thanks for pointing it out!
ok, i think i get it.
change in KE of bullet = 1/2 m(vf2 -vi2)
= (1/2)(5/1000)(1002-4002) = -375J
change in KE of spring = (1/2)(1)(1.52 - 02) = 1.125J
total change in KE = -375 + 1.125 = -373.875 = -374J (round up to 3sf)
Is this correct? :)
Related Threads on Linear momentum and collision
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
