Exploding Spaceship: Calculating Velocity and Energy
In summary, a 2710000kg spherical spaceship in deep space explodes into two pieces, one 3.61 times the mass of the other. Three scenarios are given: (a) the ship is initially at rest, (b) the ship is initially moving at a constant velocity of 48.9m/s, and (c) the ship is initially moving at a constant velocity of 48.9m/s in the opposite direction. In all three scenarios, the velocity of the larger piece can be calculated using the conservation of linear momentum. Additionally, the energy supplied by the explosion can also be calculated. This demonstrates an understanding of the concept of conservation of linear momentum.
rishabh_k
a 2710000kg spherical spaceship in deep space explodes into two pieces, one 3.61 times the mass of the other. (a) suppose the ship is initially at rest, and after the explosion the smaller piece is moving at 70.9m/s. Find the velocity of the larger piece. Find the energy supplied by the explosion.
(b) Suppose the ship is initially moving at the constant velocity 48.9m/s.After the explosion, the smaller piece is moving 70.9m/s in the same direction as the initial velocity. Find the velocity of the larger piece.
(c) Suppose the ship is initially moving at constant velocity 48.9m/s. After the explosion, the smaller piece is moving -70.9m/s.Find the velocity of the larger piece.
Surprise me and show me you knew all along that linear momentum was conserved.
I would approach this problem by first understanding the concept of momentum conservation. According to the law of conservation of momentum, the total momentum of a system before and after an event remains constant. In this case, the explosion of the spaceship can be considered as an event, and the total momentum of the system (spaceship and its pieces) before and after the explosion should be equal.
(a) Using the law of conservation of momentum, we can write the equation:
m1v1 + m2v2 = (m1 + m2)v
Where m1 and m2 are the masses of the two pieces, v1 and v2 are the initial velocities of the two pieces, and v is the final velocity of the combined system.
We are given that the mass of the larger piece is 3.61 times the mass of the smaller piece, so we can write:
m1 = 3.61m2
Substituting this in the equation and solving for v, we get:
v = (m1v1 + m2v2) / (m1 + m2)
= (3.61m2 * 0 + m2 * 70.9) / (3.61m2 + m2)
= 70.9 / 4.61
= 15.38 m/s
Therefore, the velocity of the larger piece is 15.38 m/s.
To find the energy supplied by the explosion, we can use the equation:
E = 1/2 * m * v^2
Where E is the kinetic energy, m is the mass, and v is the velocity.
Substituting the values, we get:
E = 1/2 * (3.61m2) * (15.38)^2
= 209.4 * m2 Joules
(b) In this case, the initial velocity of the larger piece is given to be 48.9 m/s, and the smaller piece is moving in the same direction with a velocity of 70.9 m/s. Using the same equation as in part (a), we get:
= (3.61m2 * 48.9 + m2 * 70.9) / (3.61m2 + m2)
= 48.9 m/s
What causes a spaceship to explode?
A spaceship can explode due to a variety of factors such as malfunctioning equipment, human error, or external forces like collisions with debris or asteroids.
How do you calculate the velocity of an exploding spaceship?
The velocity of an exploding spaceship can be calculated by using the formula v = d/t, where v is the velocity, d is the distance traveled, and t is the time it takes for the explosion to occur.
What is the relationship between velocity and energy in an exploding spaceship?
The energy of an exploding spaceship is directly proportional to its velocity. This means that as the velocity of the spaceship increases, so does the amount of energy released during the explosion.
Can the velocity of an exploding spaceship be controlled?
Yes, the velocity of an exploding spaceship can be controlled through various means such as propulsion systems, gravitational forces, and aerodynamic designs. However, in the event of an explosion, the velocity is not controllable.
Why is it important to calculate the velocity and energy of an exploding spaceship?
Calculating the velocity and energy of an exploding spaceship is crucial for understanding the potential impact and damage of the explosion. It also allows for better preparation and safety measures to be put in place to minimize potential harm.
