Linear Motion problem
Wondering if im on the right track with below question
A body is projected vertically upwards from ground level with an initial velocity of 400m/s. determine;
(a) Time to reach the ground
(b) Velocity at a point 1.8km above the ground
(c) Time to reach a vertical height of 2.5km.
(a)
u=440m/s
v=0m/s
a=-9.81m/s
v=u+at
0=400+(-9.81)t
-400/-9.81=t
t=40.77sec
total time to reach ground 40.77*2=81.54sec
(b)
s=ut+1/2at2
s=400*40.77+1/2*(-9.81)*40.772
s=1908 + (-8153.05)
s=-6245.05 m = 6.24km
Answers and Replies
adjacent
63
Where's c? And why did you find the distance for b when it asked for the velocity?
only half way through (b) haven't started (c)
though I need the distance to calculate the velocity at 1.8km? maybe I m wrong?
haruspex
Insights Author
2020 Award
36,970
7,209
(b)
s=ut+1/2at2
Why are you using half the time from part (a)? That will give you the maximum height, no? The question does not ask for that.
You are given initial speed, acceleration, distance, and you are asked for final speed. What SUVAT equation connects those four?
(Btw, you dropped a factor of 10 in the first term of the calculation, giving you a negative maximum height. You should have realised that meant you'd made a mistake, but instead you just changed the sign.)
I should use V2=U2+2as
V2=4002+2*(-9.81)*1.8
V2=square root of 159964.684
V=399.95m/s
(c)
Having trouble transposing formula to find time for part (C) not sure if the below is correct?
S=2.5kn or 2500m
u=400m/s
v=0m/s
S=(u+v)/2*t
t=s/(u+v)/2
t=2500/(400+0)/2
t=12.5sec
adjacent
63
V=399.95m/s
1.8 was given in kilo meters.You should use SI units in the Kinematics equations.
You have used m/s for speed m/s^2 for acceleration and a wrong distance.Convert it to meters first.
Related Threads on Linear Motion problem
  • Last Post
10K
  • Last Post
  • Last Post
9K
  • Last Post
