How Do You Calculate Acceleration and Maximum Height in Linear Motion Problems?
To find the total time the rocket is in the air, we can use the equation d = vit + 1/2at^2, where d is the total distance traveled (150 m), vi is the initial velocity (50 m/sec), and a is the acceleration (2 m/sec^2). Rearranging the equation, we get t = (-vi ± √(vi^2 + 2ad))/a = (-50 ± √(50^2 + 2(2)(150)))/(2) = (-50 ± √1000)/2 = (-50 ± 31.62)/2. Since time cannot be negative, we can take the positive value of t, which would
thermisius
2 linear motion problems
hi i have 2 questions on linear motion that i could use some help on step by step.
1. Jules Verne in 1865 proposed sending men to the moon by firing a space capsule from a 220-m cannon with final velocity of 10.97 km/sec.. What would have been the unrealistically large acceleration experienced by the space travelers during launch? Compare your answer with the free-fall acceleration,9.8 m/sec.
2. A model rocket is launched straight upward with an initial speed of 50.0 m/sec.. It accelerates with a constant upward acceleration of 2.00m/sec2 until its engines stop at an altitude of 150 m. (a) what is the maximum height reached by the rocket? (b) how long after lift off does the rocket reach its maximum height? (c) How long is the rocket in the air?
a= change in v/t d=averageV multiplied by time vf
vf= a multiplied by t + vi
d= 1/2a multiplied by t2 + vi multiplied by t + hi
1. for number one i am stuck because all the question gives me is final velocity and i don't know how i can only use that to find the acceleration.
2. As for number two i plugged in the information in d= .5a multiplied by t + vi multiplied by t + hi
to get d= 1/2 (2m.) multiplied by sec2 + 50m/sec multiplied by sec. + 0
but I am confused on how to figure the answer because i get d=51m./sec2
but that doesn't seem right.
Thank you for your post. I am happy to help you with your linear motion problems.
1. To find the acceleration experienced by the space travelers during launch, we can use the equation vf = vi + at, where vf is the final velocity (10.97 km/sec), vi is the initial velocity (0 km/sec), and a is the acceleration. Rearranging the equation, we get a = (vf - vi)/t. Since the question does not provide a time, we can assume that the space capsule reaches its final velocity in a very short time, almost instantaneously. This means that t can be considered to be 0. Therefore, the acceleration experienced by the space travelers during launch would be (10.97 km/sec - 0 km/sec)/0 = infinity. This is an unrealistically large acceleration and is not possible in real life.
To compare this with the free-fall acceleration, we can use the equation a = g, where g is the free-fall acceleration (9.8 m/sec^2). We can see that the acceleration experienced by the space travelers during launch is much larger than the free-fall acceleration.
2. For this problem, we can use the equations d = vit + 1/2at^2 and vf = vi + at.
(a) To find the maximum height reached by the rocket, we can use the equation vf^2 = vi^2 + 2ad, where vf is the final velocity (0 m/sec), vi is the initial velocity (50 m/sec), and a is the acceleration (2 m/sec^2). Rearranging the equation, we get d = (vf^2 - vi^2)/2a = (0^2 - 50^2)/2(2) = -625 m. However, since the rocket is moving upward, the maximum height reached by the rocket would be 625 m.
(b) To find the time it takes for the rocket to reach its maximum height, we can use the equation vf = vi + at. Rearranging the equation, we get t = (vf - vi)/a = (0 m/sec - 50 m/sec)/2 m/sec^2 = -25 sec. However, since time cannot be negative, we can take the absolute value of t, which would be 25 sec. Therefore, the rocket reaches its maximum height after 25
1. What is linear motion?
Linear motion is the movement of an object in a straight line, with a constant velocity or acceleration.
2. What are the basic equations for linear motion?
The basic equations for linear motion are:
- Position (x) = Initial position (xo) + Velocity (v) * Time (t)
- Velocity (v) = Initial velocity (vo) + Acceleration (a) * Time (t)
- Acceleration (a) = (Final velocity (v) - Initial velocity (vo)) / Time (t)
- Displacement (d) = (Final velocity (v)^2 - Initial velocity (vo)^2) / 2 * Acceleration (a)
3. What is the difference between speed and velocity in linear motion?
Speed refers to how fast an object is moving, while velocity refers to how fast an object is moving in a specific direction. For example, a car traveling at 60 mph has a speed of 60 mph, but if it is traveling north, its velocity would be 60 mph north.
4. How do we calculate the average velocity in linear motion?
The average velocity in linear motion is calculated by dividing the total displacement by the total time taken. This can be represented by the equation: Average velocity (v) = Displacement (d) / Time (t).
5. What are some real-life examples of linear motion?
Some real-life examples of linear motion include:
- Throwing a ball in a straight line
- A car driving on a straight road
- A person walking in a straight line
- A roller coaster moving along a straight track
- A pendulum swinging back and forth in a straight line
- A bullet being fired from a gun
- A bullet train traveling on a straight track
  • Classical Physics
