Linear Operator
  1. Apr 14, 2013 #1
    Show that every linear operator L:ℝ→ℝ has the form L(x) = cx for some c in ℝ.
    2. Relevant equations
    A linear operator in vector space V is a linear transformation whose domain and codomain are both V.
    3. The attempt at a solution
    If L is a vector space of the real numbers to the real numbers, then I need to show that by multiplying any scalar to an element of the real numbers, then that will yield another real number in the domain of V. Well, assume to the contrary. That is, there exists a scalar c, such that c times an element x in ℝ, yields a number that is not in the reals. Well, the only c that would work is a number that is not contained in the ℝ. However, from hypothesis, c is in ℝ. Therefore, this is a contradiction.
    Does this seem right?
  3. Apr 14, 2013 #2
    Dick
    No, that doesn't have anything to do with linearity. Write x=x*1. Now apply linearity to that.
  4. Apr 14, 2013 #3
    Would you use induction. And show that since x=x*1 is true. Assume that it is only true for n. Then show that it is true for n+1.
  5. Apr 14, 2013 #4
    Bacle2
    Maybe you can thinkof it this way: your map has a matrix representation with respect to a basis. What is a basis for the reals as a vector space over itself?
  6. Apr 14, 2013 #5
    It would be a basis if it spans the reals and is linearly independent. Therefore, from multiplying by a constant that is an element of the reals, the basis would still span the vector space.
  7. Apr 14, 2013 #6
    Dick
    No, that's not what I'm thinking. I'm thinking L(x)=L(x*1)=xL(1). How might that help you?
  8. Apr 14, 2013 #7
    By the communitiy property, you can see that any real number multiplied by x can be separated so that the codomain and domain are both in V.
  9. Apr 14, 2013 #8
    Dick
    I'm not sure what that has to do with the problem, but sure, L maps V to V. Now what about this constant c you are supposed to prove exists?
  10. Apr 14, 2013 #9
    Because L maps V to V, any constant times a real number will map to another Real number in V
  11. Apr 14, 2013 #10
    Dick
    Sure any real constant times a real number gives a real number. I don't see how that proves L(x)=cx. L(x)=x^3 also maps real numbers to real numbers. So?
  12. Apr 14, 2013 #11
    COuld you say that any real number could be represented by the real number x 1, therefore, from factoring it out, you can show that L(x) = product of c and x.
  13. Apr 14, 2013 #12
    Dick
    Why don't you try and say what c is in terms of L? I gave you a big hint a while back.
  14. Apr 14, 2013 #13
    c is 1, where x is any real number. thus 1 times x = x for all c in R
  15. Apr 14, 2013 #14
    Dick
    L(x)=x is one particular linear operator. There are other operators where c isn't 1. Look, I'll say it again. L(x)=L(x*1)=xL(1). Think about that and what you have to prove.
  16. Apr 15, 2013 #15
    Bacle2
    Another approach: Any non-zero element in the reals is a basis for R over itself. Then the representation of a linear map L :R-->R must be given by a 1x1 matrix times x....
  17. Apr 15, 2013 #16
    Why must it be given by a 1 x 1 matrix. Is this the determinant? ANd what would this muliply
  18. Apr 15, 2013 #17
    HallsofIvy
    If you did not understand Dick's "L(x)= L(x(1))= xL(1)", you need to write out the definition of "Linear Transformation". If you know the definitions, this problem should have taken you about two minutes.
  19. Apr 15, 2013 #18
    Fredrik
    Staff Emeritus
    This is much harder, since the concept of matrix representation of linear operators is somewhat difficult. It's certainly something that not everyone is familiar with (which is kind of ridiculous, considering that it's one of the most important things in linear algebra, but still). Also, if they don't understand that, then they don't understand what you mean by "R over itself" either.
    LosTacos, if you don't understand that Dick has given you the complete solution twice, the problem has to be that you don't understand what the statement that you're supposed to prove means. So I suggest that you focus on that. Make sure that you understand every single word in the statement you're supposed to prove, in particular "linear".
  20. Apr 15, 2013 #19
    Bacle2
    Because a linear map between R^n and R^m is given by an nxm matrix once you choose a basis. Yes. Any (1-dimensional ) vector, i.e.,any number.
  21. Apr 15, 2013 #20
    Bacle2
    But, if I understood the argument well, I think Dick has only addressed the homogeneous aspect of a linear map, i.e., the fact that L(cx)=cL(x) ,and not the additivity,i.e., L(x+y)=L(x)+L(y). I'm pretty sure that every homogeneous linear map from R to itself is linear, but I think this needs to be addressed in the argument. But you may be right in that ,maybe matrix representations are not too natural.
    I also had the impression from Los Tacos' post that he was familiar with matrices and matrix multiplication.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Linear Operator
  1. Linear operator (Replies: 1)
  2. Linear Operator (Replies: 25)
  3. Linear operators (Replies: 2)
  4. Linear operator (Replies: 1)
Loading...
