Homework Help: Linear Spaces (Vectors)
  1. Jan 29, 2009 #1
    From the course of Linear Algebra and Analytic Geometry
    I need to find the dimension and two different bases of subspace R3 generated by vectors (1,2,3), (4,5,6), (7,8,9).
    2. Relevant equations
    None.
    3. The attempt at a solution
    I tried
    (a,b,c)=α1(1,2,3)+α2(4,5,6)+α3(7,8,9)
    which became
    a = α1 + 4α2 + 7α3
    b = 2α1 + 5α2 + 8α3
    c = 3α1 + 6α2 + 9α3
    which (by Gaussian elimination) became an undetermined system with free variable α3.
    4. The solution given by teacher
    dim=2, example of bases={(1,0,-1),(0,1,2)} or {(2,1,0),(-1,0,1)}
    I don't want the solution, I just want to understand the mechanics on how to find the bases and the generated subspace. If someone could explain it to me, thank you.
  3. Jan 29, 2009 #2
    Mark44
    Staff: Mentor
    The system of equations you show would be used to find the span of your three vectors. Instead of equations that start with a= , b=, and c=, put 0 in for all three of those variables. You should end up with a row of zeroes and two nonzero rows.
    What did you end up with when you row-reduced your matrix?
  4. Jan 29, 2009 #3
    So, I should have used the homogeneous system A . x = 0 ? Being A a matrix. Hmm...
    I ended up with (after Gaussian elimination):
    Code (Text):
    [ 1  4  7 | a      ]
    [ 0 -3 -6 | b-2a   ]
    [ 0  0  0 | c-a-2b ]
  5. Jan 29, 2009 #4
    Mark44
    Staff: Mentor
    If I can backpedal a bit, your work is fine. For the system represented by your augmented matrix to be consistent, it must be that c - a - 2b = 0.
    or
    Code (Text):
    a = -2b + c
    b =    b
    c =          c
    I added the 2nd and 3rd equations above so that I can get some vectors out of the equation c - a - 2b = 0. The equations I added are obviously true for all values of b and c, respectively.
    Any vector [a b c]^T is a linear combination of [-2 1 0]^T and [1 0 1]^T. These come from setting b = 1, c = 0 and then b = 0, c = 1.
    Different pairs of choices for b and c will give you different pairs of vectors for your basis.
    Hope that helps.
