Linear System Question
  1. Jul 11, 2012 #1
    I'm trying to solve #1 here:
    http://www.student.math.uwaterloo.ca/~math115/Exams/M115.FE.pdf [Broken]
    The problem is:
    3. The attempt at a solution
    (a) At a=2, the slope is the same. I figure any value but 2 gives unique solutions. But I don't know if this is right.
    (b) At a=2, the slopes are the same, but lines are different. I cannot find any value of a that would give the same slope and same outputs for inputs of x. DNE is the answer?
    (c) At a=2, there are no solutions for the system because the lines are parallel to each other. a=2 is the answer.
    (d) I think this part was done correctly. I used substitution and solved for the x and y values at a=1 and resulted with (2/3, 1/3)
    I would like to know about a, b, and c. I don't know if I did these right.
    Thanks.
  3. Jul 11, 2012 #2
    eumyang
    Ignoring (a) and (b) for the moment:
    (d) is right, but (c) is wrong. At a = 2, you have this system:
    x + 2y = 1
    2x + 4y = 2
    Parallel lines have the same slope, but different y-intercepts. Is that the case here?
  4. Jul 11, 2012 #3
    chiro
    Hey JettyZ.
    For c), there are many solutions corresponding to x = t and y = 1 - 2t for any value of t.
    For a) and b) you need to use determinants and check for possibilities of inconsistent solutions.
  5. Jul 11, 2012 #4
    HallsofIvy
    If a= 2, your equations are x+ 2y= 1 and 2x+ 4y= 2. If you multiply the first equation by 2, what happens? What does that tell you?
  6. Jul 11, 2012 #5
    Ray Vickson
    Do you know about determinants and their relationship to such questions? If so, use a determinant; you will see that there is a critical value of 'a' that you have missed.
    RGV
Similar Discussions: Linear System Question
  1. Homogenous linear system (Replies: 12)
Loading...
