Linear Systems
The transfer function of a linear system is known in the sinusoidal frequency domain. It is given in its final form as a complex function of the angular frequency ω (not jω ). How to obtain the step response?
Thanks in advance.
Answers and Replies
jasonRF
531
In order to figure this out you need to know two things:
1. The relationship between the transfer function and the impulse response
2. The relationship between the impulse response and the step response
Hopefully this points you in the correct direction.
jason
Simon Bridge
17,874
1,655
How would you normally obtain the step response given the transfer function?
Note: If you have ##s=j\omega## - then ##f(\omega) = f(-js)## right?
If you prefer, you can fourier transform back to time domain, then transfer to frequency domain like you are used to.
Dear friends:
Thanks for your kind comments. In the meantime I could find a direct straightforward answer in the 1959 publication:
SIMPLIFED METHOD OF DETERMINING TRANSIENT RESPONSE
FROM FREQUENCY RESPONSE OF LINEAR NETWORKS AND SYSTEMS
By: Victor S . Levadi
Thanks again.
Boudy
Simon Bridge
17,874
1,655
Excellent - perhaps you could summarize what you found?
In order to find the Impulse response , f(t), you need only the real part , R(ω),of the transfer function
F(j ω).
According to the mentioned paper:
f(t)= (2/π).R(ω).cos(tω) dω
The limits of integration are from zero to infinity.
Best regards
Likes Simon Bridge
Related Threads on Linear Systems
  • Last Post
  • Last Post
  • Last Post
