Linear transformation matrix problem
In summary, the conversation discusses finding the matrix C of the linear transformation T(x) = B(A(x)), where A and B represent two linear transformations with respect to a pair of bases. The solution involves multiplying the matrices A and B to obtain the matrix C, which represents the composition of the two transformations.
snoggerT
186
let A= [tex]\left(
\begin{array}{Ccc}
9 & 0 \\
2 & 6 \\
\end{array}
\right)[/tex]
and B= [tex]\left(
\begin{array}{Ccc}
5 & 1 \\
3 & 4 \\
\end{array}
\right)[/tex]
Find the matrix C of the linear transformation T(x)=B(A(x)).
- Once again, I really don't know how to start a problem like this off. I tried finding just T(x)=Ax and then multiply that by B, but that didn't seem to work. Please help.
If A and B represent two linear transformations f and g with respect to a pair of bases, then g(f) is just BA.
okay, I see that now. thanks.
What is a linear transformation matrix?
A linear transformation matrix is a mathematical tool used to describe how a geometric object or set of coordinates is transformed. It is represented as a rectangular array of numbers and can be used to rotate, scale, reflect, or shear an object.
How do you multiply a vector by a linear transformation matrix?
To multiply a vector by a linear transformation matrix, you simply need to multiply the vector's coordinates by the corresponding elements in the matrix and then add the results together. The resulting vector will be the transformed vector.
What is the purpose of using a linear transformation matrix?
The purpose of using a linear transformation matrix is to simplify and generalize transformations of geometric objects. It allows for easy calculations and can be applied to any object with the same matrix, regardless of its size or orientation.
What is the difference between a linear transformation matrix and an identity matrix?
A linear transformation matrix is used to represent any type of transformation, while an identity matrix is a special type of linear transformation matrix that does not change the object at all. It is represented by a diagonal matrix with all 1's on the main diagonal and 0's everywhere else.
Can a linear transformation matrix be used to perform multiple transformations at once?
Yes, a linear transformation matrix can be multiplied by another linear transformation matrix to combine multiple transformations into one. This is known as matrix composition and allows for more complex transformations to be easily calculated.
