Linear Velocity
  • Thread starter Miike012
Miike012
1,011
Linear Velocity....
When do I use
v = S/t
OR
v = R*w
s= arc length
w = angular velocity
t = time
Answers and Replies
HallsofIvy
41,847
969
You use the formulas that use the information you are given!
If you are given an "angular velocity" or an "radius", R, then you use v= Rw. If you are given an actual length and time, then you use v= S/T.
banglajihwan
the equation v = R*w shows that when you have a simple rotating object, and when w is constant (not changing), the linear velocity of the object (v) increases as you go further away from the origin (as R increases). As R increases, the object has to travel more but w is the same, so v must increase also.
Suggested for: Linear Velocity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
