Lineary DE in Kinematics
  1. Jan 14, 2005 #1
    Linear DE in Kinematics
    Hey
    I would like to know, how it is possible to solve the following
    differentialequations
    [tex]\ddot{x}(t)+\alpha \dot{x}(t)^2=0[/tex]
    and the one that really gives troubles
    [tex]\ddot{y}(t)+\alpha\dot{y}(t)^2=-g[/tex]
    when given that [tex]x(0)=0[/tex], [tex]y(0)=0[/tex], [tex]\dot{y}(0)=v_0\sin \theta[/tex] and [tex]\dot{x}(0)=v_0\cos \theta[/tex]. Where [tex]\alpha=k/m[/tex]. The problem in equation 2 is, that i can't even solve the integral
    [tex]\int \frac{1}{-g-\alpha \dot{y}^2}\:d\dot{y}[/tex]
    Doing the substitution here doesn't get get me anywhere. Maybe someone have made this problem before, it's motion in 2-dimensions, with
    airresistance. The 2 equations comes from
    [tex]m\vec{a}=\vec{F}_g - \vec{F}_{airr}[/tex]
  3. Jan 14, 2005 #2
    dextercioby
    HINT:not [\tex],but [/tex]
    Daniel.
  4. Jan 14, 2005 #3
    dextercioby
    1.Your equations are not linear.
    2.Write them using the velocity.E.g.
    [tex] m\frac{dv(t)}{dt}-kv^{2}(t)=-mg [/tex]
    Can u solve it,now??
    Daniel.
  5. Jan 14, 2005 #4
    That doesn't help, I started by writing it in that way, but then rewrited it here. The problem is the integral
    How can you solve this. By using the substitution, you end up with an even more complicated integral, and partial integration doesn't help. Can you that problem? I hope you can help me. Thanks in advance.
  6. Jan 14, 2005 #5
    dextercioby
    Can't u solve this integral??
    [tex] \int \frac{dv}{-mg+kv^{2}} [/tex]
    Daniel.
    PS.If u can't,what are u doing solving ODE-s??
  7. Jan 14, 2005 #6
    arildno
    Dearly Missed
    Check up an arcus tangens and artanh (inverse of hyperbolic tangens)
  8. Jan 14, 2005 #7
    dextercioby
    Let's not go there,Arildno... :tongue2: Maybe separation into simple fractions...?? :rolleyes:
    Daniel.
  9. Jan 14, 2005 #8
    No I can't solve this integral:
    Because when I substitude lets say
    [tex]u=-mg+kv^{2}[/tex]
    then
    [tex]v=\sqrt{\frac{u+mg}{k}}[/tex]
    and
    [tex]\frac{du}{dv}=2kv \Leftrightarrow dv=\frac{du}{2kv}[/tex]
    But when I use the partial integration technique, I end up with a even more complicated integral.... Try solve it and you will see. Perhaps I should check up an arcus tangens and artanh?
  10. Jan 14, 2005 #9
    dextercioby
    Do u have any experience doing integrals??In this case,u can decompose the fraction/integrand into 2 simple fractions.
    Daniel.
    PS.Do you know this integration technique??
  11. Jan 14, 2005 #10
    If you want to use an inverse hyperbolic/trig integral, don't subsitute like this. What you need to do is make the denominator into the form 1 - av^2 (where a is a constant (can you see how to do that?), then you can look up what this integral is. It's not arctan, as d/dx (arctan x) = 1/(1 + x^2), but I can't remember which one it is.
  12. Jan 16, 2005 #11
    looking up integrals :bugeye: ? just draw a right triangle... make pythagoras proud :rofl: [/hint] :devil:
    if you use trig substitution, you'll get to [tex]\int\sec\theta\ d\theta = \ln | \sec\theta + \tan\theta |+C[/tex] which will be the same as if you were to go by seperation.
  13. Jan 17, 2005 #12
    Well, I havn't been online for 2 days now, but I have solved the ODE. I just jused arctan Nylex says.
  14. Jan 17, 2005 #13
    dextercioby
    WHAT??U mean "arctanh" as from "arcus tangens hyperbolicus",right???
    As i said,partial fraction would have dunnit much easier.
    Daniel.
  15. Jan 17, 2005 #14
    No, I used arctan;
    [tex]\frac{d}{dx}\arctan x=\frac{1}{1+x^2}[/tex]
    And yes I sepretated into simple fractions.
  16. Jan 17, 2005 #15
    dextercioby
    Then your result was WRONG,WRONG!!!!!!You should have used "arctanh".
    Daniel.
    PS.Are u sure it was the integral discussed above,the one with one minus at the denominator??
  17. Jan 17, 2005 #16
    dextercioby
    Please,separate into simple fractions
    [tex] \frac{1}{1+x^{2}} [/tex]
    Daniel.
  18. Jan 17, 2005 #17
    I have the calculations in Mathcad, how can I upload a file in here, so that you can see them..
  19. Jan 17, 2005 #18
    dextercioby
    If it's not more than 50KB,you can post them as an attachement.OOPS,can u transfer them into another format??Attachment manager doesn't support "mathcad/matlab" files,sorry.
    Try to post the general idea,at least.
    Valid extensions:
    "Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd txt zip"
    Daniel.
  20. Jan 17, 2005 #19
    Here is how i solve it;
    [tex]m\frac{d}{dt}v_y(t)+kv_y(t)^2=-mg[/tex]
    [tex]\frac{d}{dt}v=-g-\alpha v^2[/tex]
    where \alpha = k/m, then
    [tex]\frac{dv}{-g-\alpha v ^2}=dt [/tex]
    [tex]\int\frac{1}{-g-\alpha v^2}dv=t + c[/tex]
    [tex]\frac{1}{-g}\int\frac{1}{1+\frac{\alpha}{g}v^2}dv=t + c[/tex]
    [tex]\frac{1}{-g}\int\frac{1}{1+\left(\sqrt{\frac{\alpha}{g}}v\right)^2}dv=t + c[/tex]
    Then i substitude
    [tex] u=\sqrt{\frac{\alpha}{g}}v[/tex]
    [tex] \frac{1}{-g\sqrt{\frac{\alpha}{g}}}\int\frac{1}{1+u^2}du[/tex]
    therefor
    [tex] \frac{-1}{\sqrt{g\alpha}}\arctan\left(\sqrt{\frac{\alpha}{g}}v\right)=t+c[/tex]
    Where does it go wrong :(?
  21. Jan 17, 2005 #20
    dextercioby
    I thought so.The initial equation is wrong.Gravity and aerodynamic force have opposite signs...
    Daniel.
    P.S.Redo calculations.
  22. Jan 17, 2005 #21
    Hmm isn't it;
    [tex] \vec{F}_{res}=\vec{F}_g-\vec{F}_{air}[/tex]
    [tex] m\begin{pmatrix} v_x'(t)\\v_y'(t) \end{pmatrix} = \begin{pmatrix} 0\\-mg \end{pmatrix} -k\begin{pmatrix} v_x(t)\\v_y(t) \end{pmatrix}^2 [/tex]
  23. Jan 17, 2005 #22
    arildno
    Dearly Missed
    Nope; you should use:
    [tex]m\frac{d\vec{v}}{dt}=-m\vec{g}-k||\vec{v}||\vec{v}[/tex]
    Think about it..
    (I am assuming zero air velocity here)
  24. Jan 17, 2005 #23
    What does [tex]||\vec{v}||[/tex] means, it's not magnetude is it??
  25. Jan 17, 2005 #24
    arildno
    Dearly Missed
    Sure it's magnitude.
  26. Jan 17, 2005 #25
    But what is the difference between;
    And my expression in #21???
