What Do These Physics Forum Terms Mean? A Quick Guide to Lingo
In summary, a thread was started in the PF forums for anyone who doesn't understand the language used in the forums to post their questions. The conversation included discussions about the abbreviations "quanta," "valency," and "QED," with explanations provided by other members. A discussion about the meaning of the abbreviation "AI" also took place. The conversation also touched on the topics of radiation, valency, and quantum energy.
The Bob
1,126
I am starting this thread for me and anyone that doesn't understand any language used in the PF forums post it here so people can say what it stands for. I have been confused once or twice in these forums. Anyway it will probably turn into something unusual like the other threads. :biggrin:
Anyway here are my words to check:
1. Quanta
2. Valency
3. QED
Cheers :biggrin:
The Bob (2004 ©)
1. Quanta
2. Valency
3. QED
Cheers :biggrin:
The Bob (2004 ©)
I have a working understanding of quanta and valency, but would probably miss something important in the definition without looking it up and using someone else's definition, so I'll leave that for the physicists/chemists to answer.
QED - Quod erat demonstratum
Oh, you probably want that translated too. :biggrin:
It's Latin for "That which was to be proven." You use it in the final statement of a proof, when you've reached the conclusion intended.
QED, if it appeared in a physics subforum, would be Quantum Electrodynamics - the Quantum theory of the interactions of energy with matter.
I believe there was a thread like this before, listing all the abbreviations/jargon used in PF.
Ok. Cheers. I am still likely to post it here though.
The Bob (2004 ©)
P.S. Thanks for the QED. I thought it knew it. Just comfirmed it.
This taking a guess but isn't a quanta a unit of energy? I am really not sure about this but i have a strange feeling between my toes telling me that it is.
Might just be athletes foot though.
Latin came first, how dare they steal the abbreviation! :biggrin: Well, I guess it's a good thing The Bob asked, and now I'm doubly glad I didn't try answering the other two.
I always get good laughs discussing the abbreviation AI with one of my friends...he's an engineer, and I'm a biologist...our first thought of what the abbreviation means are two VERY different things...he says it's artificial intelligence and I insist to him it's artificial insemination. But you all might be able to settle things for us if anyone can tell me when the term artificial intelligence was first used. We've been trying to figure out which one came first, but I think they may have both come about at similar times (I'm not telling him that though :wink: ...I'm still insisting artificial insemination came first, which is of course why it's the correct use of the abbreviation :biggrin:)
Quanta are discrete packets of energy. If you have radiation of some frequency, f, then the total energy of the radiation must be an integer multiple of 'hf' - which is referred to as a quantum of energy. 'h' is the Planck's constant ~ 6.626 * 10^-34 Js. A quantum of electromagnetic radiation is a photon.
Valency is the number of electrons that need to be added or removed from the outermost shell of an atom to make it have a fully filled outer shell. Sodium (Na) has 1 electron in its outer shell. It is easier to remove this one electron than to add 7 more to fill the shell. Thus, Na is said to have a valency of +1. Oxygen has 6 electrons in its outer shell, and finds it easier to add 2 electrons to fill this shell. O has a valency of -2. When Na reacts with O, the O atom takes 1 electron from each of two Na atoms (which are happy to give up an electron each). Hence the compound that is formed has the formula Na2O. Thus the valencies determine the ratios in which different elements react to form compounds.
Thanks about this part Gokul. It has been annoying me for ages not knowing what valency is. :biggrin:
I will think about what you said and re-read the part about quanta because it is not making sense to me at the minute. Cheers all the same
The Bob (2004 ©)
P.S. Oh and not to forget Moonbear with the QED version I wanted. Cheers darling. :wink:
I was kinda rite in the vaguest possible way.
The Bob (2004 ©)
I wouldn't expect it to. There's a lot of reading that needs to be done to fully appreciate quantization of energy.
Check these out :
http://www.google.com/search?hl=en&lr=&ie=UTF-8&oi=defmore&q=define:quantum
1. What is the difference between "force" and "energy" in physics?
Force and energy are two fundamental concepts in physics, but they have different meanings. Force refers to a push or a pull on an object that causes it to accelerate or change direction. Energy, on the other hand, is the ability of an object to do work. In other words, force is a cause of motion, while energy is a measure of motion.
2. What is the significance of "mass" in physics?
Mass is a measure of the amount of matter in an object. It is a fundamental property of matter and is often described as the "quantity of inertia." In physics, mass is a crucial factor in determining an object's resistance to changes in its state of motion. It also plays a significant role in the equations that describe the relationship between force, acceleration, and velocity.
3. What is the difference between "kinetic" and "potential" energy?
Kinetic energy is the energy of motion, while potential energy is the energy an object possesses due to its position or state. In other words, kinetic energy is the energy an object has because it is in motion, while potential energy is the energy it has because of its position or condition. When an object changes from one position to another, its potential energy can be converted into kinetic energy and vice versa.
4. What are "laws of motion" in physics?
The laws of motion are a set of three fundamental principles proposed by Sir Isaac Newton in the 17th century. They describe how objects move in response to forces acting on them. The first law states that an object will remain at rest or in motion in a straight line at a constant speed unless acted upon by an external force. The second law explains the relationship between force, mass, and acceleration. The third law states that for every action, there is an equal and opposite reaction.
5. What is the difference between "velocity" and "acceleration"?
Velocity and acceleration are both measurements of an object's motion, but they have different meanings. Velocity is a measure of the rate of change of an object's position with respect to time. In other words, it is the speed and direction of an object's motion. Acceleration, on the other hand, is the rate of change of an object's velocity with respect to time. It is a measure of how quickly an object's velocity is changing. In simple terms, velocity tells us how fast an object is going, while acceleration tells us how quickly its speed is changing.
  • General Discussion
  • STEM Academic Advising
  • Biology and Medical
18K
  • Quantum Physics
15K
