Metallicbeing
- 71
I'm running Windows XP Pro w/ SP2. The so called "firewall" has slowed my broadband down considerably. I was told that if I had a router, I didn't need Window XP's "firewall". Is this true?
el-half said:I have a router, and I don't use a firewall on my computer. In practice, if you are a 'safe user' there is not really a need for a firewall when using a router.
I also don't know whether XP SP2's firewall has got outbound protection, at least the original didn't.
A LinkSys router is a type of networking device that connects multiple devices to the internet. It acts as a central hub for all devices in a network, allowing them to communicate with each other and access the internet through a single internet connection.
The setup process for a LinkSys router can vary depending on the model, but generally involves connecting the router to your modem and then following the instructions provided by the manufacturer. This may include accessing the router's settings through a web browser and entering your internet service provider's information.
Yes, LinkSys routers are compatible with most internet service providers. However, it is always recommended to check with your internet service provider before purchasing a router to ensure compatibility.
The number of devices a LinkSys router can support depends on the model and its specifications. Some routers can support a few dozen devices, while others can support hundreds or even thousands. It is important to check the specifications of the specific router model to determine the maximum number of supported devices.
To secure your LinkSys router, you can set up a strong password and network name, enable encryption, and disable remote management. You can also limit the number of devices that can connect to your network and regularly update your router's firmware to ensure it has the latest security updates.
