Exploring .NET 3.x: LINQ, XLing, & Dling
  • Thread starter -Job-
In summary, the LINQ project is a feature of .NET 3.x that supports SQL-like statements for arrays and collections. It also includes XLinq and DLinq for integrating with XML and databases, respectively. Examples of LINQ usage can be found on the Microsoft website and a CTP version of Visual Studio Orcas is available for developers to try it out. It is seen as a significant development in object-oriented languages and is a part of the .NET Framework. The project has been updated since its initial release, with the current version being 4.7.2 as of April 2019. For more information on LINQ, the updated link can be found on the Microsoft website.
-Job-
EDIT: I meant to post this in the Programming Forum, if a mod can please move it...
Have you heard of the LINQ project? I recently came across it.
Since .NET 3.x is going to support Lambda expressions, .NET developers will introduce LINQ (Langauge Integrated Query) which supports SQL-like statements for arrays and collections.
Along with it are coming XLing and Dling for creating classes which integrate seamlessly with an XML or Database schema respectively.
Here are some examples:
Code:
public void Linq6() {
    int[] numbers = { 5, 4, 1, 3, 9, 8, 6, 7, 2, 0 };
    var numsPlusOne =
        from n in numbers
        select n + 1;
    Console.WriteLine("Numbers + 1:");
    foreach (var i in numsPlusOne) {
        Console.WriteLine(i);
Code:
public void Linq88() {
   List products = GetProductList();
   var categories =
      from p in products
      group p by p.Category into g
      from maxPrice = g.Group.Max(p => p.UnitPrice)
      select new {Category = g.Key, MostExpensiveProducts = g.Group.Where(p => p.UnitPrice == maxPrice)};
   ObjectDumper.Write(categories, 1);
Some more examples at: http://msdn2.microsoft.com/en-us/vcsharp/aa336747.aspx
The LINQ Project: http://msdn2.microsoft.com/en-us/netframework/aa904594.aspx
You can download a CTP version of Visual Studio Orcas (the next Visual Studio release), which includes .NET 3.5 and allows you to develop with LINQ.
http://www.microsoft.com/downloads/...3d-5e79-4126-b4c0-8db6332de26e&displaylang=en
This is a new direction for OO languages and independently of whether it will be a success or a failure (personally i think it's a great idea) it's important to keep up with the times.
Computer science news on Phys.org
1. What is .NET 3.x and what is its significance?
.NET 3.x is a programming framework developed by Microsoft that provides tools and libraries for developers to create applications for Windows, web, and mobile platforms. It is significant because it allows for faster and more efficient development of applications, with features such as automatic memory management and a vast collection of reusable code.
2. What is LINQ and how does it work?
LINQ (Language Integrated Query) is a feature of .NET 3.x that allows developers to query data from various sources, such as databases, XML files, and collections, in a unified and easy-to-understand syntax. It works by using a set of query operators and expressions to manipulate data, similar to how SQL is used to query databases.
3. What is XLinq and how does it differ from LINQ?
XLinq (XML Language Integrated Query) is a variation of LINQ specifically designed for querying XML data. It uses the same syntax and operators as LINQ but is optimized for working with XML documents, allowing for easier manipulation and traversal of data within the document.
4. What is Dlinq and how does it fit into the .NET 3.x framework?
Dlinq (Data Language Integrated Query) is a component of LINQ that allows developers to query databases using LINQ syntax. It allows for easy integration of database queries with other LINQ queries, providing a unified way to access and manipulate data from various sources within an application.
5. How does .NET 3.x compare to previous versions of .NET?
.NET 3.x introduced several new features, such as LINQ, XLinq, and Dlinq, which were not available in previous versions. It also improved upon existing features, making development more efficient and streamlined. Additionally, .NET 3.x is compatible with previous versions, so applications written in earlier versions can still run on .NET 3.x without any major changes.
