- 3
I have a question on the interpretation of the LS-equation.
[tex]\psi^{\pm} = \phi + \frac{1}{E- \mathcal{H} \pm \epsilon} V\psi^{\pm}[/tex] (1)
Deriving the equation was simply because the Hamiltonian can be written as H=H0 + V where H and H0 have the same eigenvalues and H0 is a free Hamiltonian. The equation can be written as
[tex]H_0|\phi> = E|\phi>[/tex]
So an interaction in the equation makes
[tex](H_0+V)|\psi> = E|\psi>[/tex]
Continuity states that as [tex]\psi rightarrow \phi[/tex] and [tex]V \rightarrow 0[/tex] then the solution has (E − H0) as singular. You can avoid the singularity when you assume a small part of the denominator in
was imaginary.
My question is as follows: This would clearly make the Hamiltonian as negative. The solution to the equation almost derives
as an automatic solution when considering it was obtained to avoid nasty singularities. Is there any physical reason to assume the Hamiltonian has an imaginary part?
was imaginary.
