Liquid Pressure: How Does It Exert Pressure?
In summary: This is because in zero gravity, there is no force acting on the molecules to cause them to move in one direction more than another, so they bounce off the body equally from all sides, resulting in no net force and equal pressure. In summary, the pressure exerted by a liquid in all directions is due to the constant motion of its molecules, which results in an equal distribution of pressure on all sides of a submerged body in a zero gravity environment.
Pranav Jha
141
how does liquid exert pressure in all directions?
When a liquid is placed in a container, i understand that it exerts pressure on the bottom of the container due to its weight but why does it exert pressure on the sides of the container?
is that due to the fact that the molecules in liquid are free to move in all directions (relatively as compared to a solid)?
this thing is really bugging me and consequently i cannot understand Pascal's law
Yes, that is because the molecules of the liquid move in all directions.
f you release a Ping-Pong ball beneath the surface of water, it will rise to the surface. Would it dothe same if submerged in a big blob of water floating weightless in an orbiting spacecraft ?
A Ping-Pong ball in water in a zero-g environment would experience no buoyant force.
This is because buoyancy depends on a pressure difference on different sides of a submerged
body. IN THE WEIGHTLESS CONDITION NO WATER PRESSURE EXISTS
If water pressure were due to movement of water molecules at microscopic level, shouldn't there be water pressure at zero gravity condition as well?
There will be pressure due too the molecules motion, but not pressure difference in the liquid, the molecules will be bouncing from the body, equally from all sides, so there wot be a force present, no relative motion.
What does "no relative motion" actually mean?
Similarly, how does the absence of gravity guarantee that the molecules bounce equally from all sides giving no net force and thus no net pressure?
Relative motion is motion of two or more bodies in respect of one and other, two cars on a highway are going in same direction one with 100 km\h and the other with 110 km\h, so there is relative motion between the two cars, with speed of 10 km\h.
If the fluid is liquid then there are intermolecular forces acting, like springs, preventing the liquid to fill all the space available, but the molecules have some kinetic energy, their number is huge, they hit each other constantly, so statistically the probability the body to be hit from each side is the same(no force is suggesting otherwise). There is no pressure difference.
In gravity field (there is force present) the pressure in fluid depends on the depth, because of the weight of the fluid. So there is pressure difference between the upper and lower surface of the body (on the lower surface there is higher pressure) creating force acting upwards, buoyant force.
Absence of gravity ensures they bounce equally on all sides, which results in equal pressure, not no pressure.
1. What is liquid pressure and how is it exerted?
Liquid pressure is the force per unit area that a liquid exerts on its container or any objects immersed in it. It is exerted in all directions and is caused by the weight of the liquid pushing down on itself and its surroundings.
2. How does the depth of a liquid affect its pressure?
The deeper a liquid is, the greater the pressure it exerts. This is because the weight of the liquid above increases with depth, resulting in a greater force per unit area. This is known as hydrostatic pressure.
3. Can the shape of a container affect liquid pressure?
Yes, the shape of a container can affect the distribution of liquid pressure within it. A container with a wider base will distribute the weight of the liquid over a larger area, resulting in lower pressure compared to a container with a smaller base.
4. How does gravity play a role in liquid pressure?
Gravity is responsible for the weight of the liquid, which in turn determines the magnitude of liquid pressure. Without gravity, liquids would not have weight and therefore would not exert pressure.
5. What are some real-world applications of liquid pressure?
Liquid pressure is used in many practical applications, such as hydraulic systems that use liquid pressure to transmit force, scuba diving where the pressure of water increases with depth, and in dams where the weight of water creates pressure to generate electricity. It is also crucial in the functioning of our circulatory system, where blood pressure is maintained to ensure proper blood flow.
