Liquifying Nitrogen
  1. Aug 15, 2014 #1
    A rigid cylinder contains 9.0g of nitrogen at 20 ∘C.
    What is the minimum amount of heat energy that must be removed to liquify the nitrogen?
    2. Relevant equations
    Heat Energy
    H = Cp * m * ΔT
    H = Heat Energy
    Cp = Heat Capacity
    m = mass (in Kg)
    ΔT = change in temperature (in Celsius)
    Heat of Condensation (Equal to Vaporisation)
    H = Hc * m
    Hc= Heat of condensation
    m= mass (in moles)
    3. The attempt at a solution
    Heat Capacity of nitrogen = 1.04 kJ/kg*K.
    Nitrogen is a liquid at -196 C, so ΔT = -196 - 20 = -216
    H = Heat Capacity * mass * ΔT
    H = 1.04 kJ/kg*K * 0.009 kg * 215 = 2.02 kJ
    H= Heat of condensation * mass (in moles)
    H= 5.56 kJ*mol * 0.32 moles = 1.78 kJ
    2.02 kJ + 1.78 kJ = 3.8 kJ
    3.80 kJ of heat energy is required to liquify the nitrogen.
    Answer isn't correct. If anyone can point me in the right direction it would be much appreciated.
  3. Aug 17, 2014 #2
    BvU
    2017 Award
    Hello says, and welcome to PF.
    You seem pretty sure the answer is not correct (how do you know?), so I will accept that.
    Why do you use cp if the exercise says the cylinder is rigid ?
  4. Aug 17, 2014 #3
    Hi BvU! Thanks for the welcome. :)
    I ended up getting this problem right. I was using the Cp value of Nitrogen and not the Cv value.
    Problem solved!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Liquifying Nitrogen
  1. Liquid Nitrogen (Replies: 2)
  2. Thermodynamics- Nitrogen (Replies: 11)
  3. Nitrogen and vacuum (Replies: 1)
Loading...
